Is distortion in electronics meaningful ?
o2so
Sydney, Australia
Quick question.
I do not understand why we fuss so much about distortion in a DAC which might be at -100db rather than -130db when the best speakers that have been tested here have second harmonic distortion at around -70db. How does it work, do they sum up? Or because the speakers has distortion at -70db it does not really matter what the DAC does?
KeithPhantom
Quick question.
Humans are pretty bad at detecting nonlinearities (distortion) by ear, so we resort to using measuring equipment that far exceeds our ability to critically hear to reveal what we cannot detect. The marginal benefits of having better measurements decrease quickly and pretty much flatten at -80 dBFS considering the use cases home audio equipment is used, so there is a limit to the audibility of distortion measurements.
bunkbail
Until a certain threshold, nope, they're not meaningful. We are just measurebating beyond that threshold.
o2so
o2so
Sydney, Australia
So I gather that any component with a distortion at - 80db will be basically indistinguishable from one with distortion at -130db? If this is the case, what is the point of measuring this difference or even caring about it?
Anyway my question was a bit more about the speaker/component relative importance in defining distortion. If the speakers go at best at -70db, who cares if the dac or the amp measure -80db rather than -130db? Am I missing something?
KeithPhantom
Technical progress, pure engineering progress. Also, it is easy and cheap to make equipment that measures -120 dBFS, so why not?
If the speakers goes at best at -70db
Don't take this number so seriously, they are quoting distortion from a single nominal value at a single volume level, not the average (or a total presented in a graph) across the frequency range. And yes, the distortion coming from transducers is way more important than the rest, since electronics are able to measure better and being more consistent.
exaudio
I'm speculating, but I'd say most of the frequent visitors to this forum look at measurements more for signs of excellence in engineering than from the perspective of audibility.
That said, a while back forum member @flipflop compiled a bunch of audibility research into a post titled Audibility Thresholds of Amp and DAC measurements.
At the end of his post he summarized the results into lenient and strict thresholds. What I took away from his post was the levels I use when interpreting @amirm's FFT spectrum plots showing SINAD. They are as follows:
-66 dBFS Lenient threshold for distortion
-85 dBFS Lenient threshold for noise
-120 dBFS Strict threshold for full transparency / provable inaudibility
One other thing to note about distortion is that, while everybody agrees that intermodulation distortion (IMD) is bad, some of the more traditional audiophiles out there find a certain level of harmonic distortion to be pleasant.
Racheski
Chicago
I don't think "easy" is the right adjective. We only have a handful of DACs and Amps that achieve -120 dBFS and they are all less than 2 years old I think.
carlosmante
You are missing bragging rights.
solderdude
The Neitherlands
Quick question.
1: As KeithPhantom already mentioned people aren't as sensitive to distortion as they might think it is.
2: Noise and frequency response and some other aspects may be more important than distortion as long as it isn't reaching absurd levels for this day and age.
3: We measure because we want to know the electrical performance this includes distortion.
4: A DAC may not be as sound determining as the interaction between an amp and a complex load but still we want to know both.
I would fuss more over FR linearity and noise in a DAC more so than distortion but all aspects have importance and need to be characterized.
When everything but distortion levels are the same the -100dB distortion and -130dB distortion levels will not be of practical importance. No one claims they do, they may feel it is important to them (piece of mind) though.
JohnYang1997
China
Transducers are noiseless. Electronics can get noisy. And electronics have different distortion mechanics than transducers. Lastly, it's not about who's 1db better. It's about who gives a bread about performance and who is full of BS.
sergeauckland
Suffolk UK
To the first sentence, I agree, for me it's a sign of correct design, not audibility.
As to the second, I can't see how one can have harmonic distortion without intermodulation distortion, as they're caused by the same mechanism, non-linearity of transfer function. That distortion can be pleasant, of that I have no doubt. Valve amplifiers of the SET variety and/or low feedback designs have both.
S.
Wombat
Australia
If it is audible and not meant to be there, then yes.
RayDunzl
Central Scrutinizer
Riverview FL
My PC, for work purposes has an alarm clock which emits eleven cycles of a cuckoo clock sound at 11pm and midnight, among a few other times, on days of weeks. It takes about 11 seconds to play. Cuckoo, cuckoo, cuckoo, etc...
Audio Buddy came over on Monday evening. He brought some new (old) music to which to listen attentively.
The Focusrite was still set to "mix" the PC sound output with whatever else was going to the DAC.
Twice, the cuckoo clock sounded during tunes, and twice I noticed it, and twice Audio Buddy didn't.
solderdude
The Neitherlands
because you are 'trained' to recognize it where audiobuddy may have thought it belonged in the recording or ignored it ?
Most likely the cuckoo clock was not mixed in at -70dB either.
RayDunzl
Central Scrutinizer
Riverview FL
I "recognized" it, yes.
It was approximately the same level as the instruments accompanying the current solo (guitar, bass drums, piano), like another player accompanied for eleven seconds or so, in neither the same key nor the same time signature.
It played, I looked at him while it was playing.
He's just bobbing along with Wes Montgomery.
"Did you hear that?"
"Hear what?"
"The cuckoo clock."
"No."
An hour later, it played again. I looked at him while it was playing.
He's bobbing to Charlie Christian (which turned out to be more like jitterbug and less emphasis on the guitar, which I found less satisfying, despite the amazing instumentalists)
"Hear what?"
"The cuckoo clock."
"No."
Surprised me, anyway.
The point being "people aren't as sensitive to distortion as they might think" as you mentioned above.
Carry on.
Harmonie
France
I really hope that there are more reasons for attending this site
Wombat
Australia
First sentence - run a poll.
