Is it possible to add this measurement or is it useless ?
versus666
Hi !
Long time lurker I finally decided to register. ASR is a GREAT source of REAL informations, really professional and I doubt to fine enough words to say how much I love that place ! :D
I love the numerous tests and the characteristics measured but as an avid gamer ( everyone have a flaw ;) ) I'm looking for the most responsive hardware and I wonder if all DACs have the same latency, if any. I know there is a way to set latencies in ASIO and ALSA but that's on the software side so do DACs, whatever their qualities, induce any latency by the way they are made, just like mice do, and is it possible to measure it in each reviews ?
zermak
Italy
This exact question was already asked before and my understanding/conclusions are that you don't have to worry about audio latencies because the main issues will always are the monitor input lag and mostly the pixels rise/fall times (response times) which are way higher time than a possible audio synch problem even with the best 240Hz monitor for gaming (best G2G I saw was 2,6ms and best input lag I saw was something line 2ms but on another monitor).
Blumlein 88
What you're thinking of is called propagation delay. Probably in the few dozen picoseconds range. The travel time in cabling will be more, and is in the nanoseconds range. Not worth bothering with.
tomtoo
Germany
Hi !
I am not a gamer. But for people that like to make real time musik with there equipment thats a very importent question too.
Blumlein 88
Yes but he is referring to hardware latency. Not the more common software latency which can run into enough milliseconds (more than 20) to be a problem for recording.
RayDunzl
Central Scrutinizer
Riverview FL
RayDunzl
Central Scrutinizer
Riverview FL
Ah...
My well documented DAC gives a "common case" number or two:
Maybe more than I expected - 59,976 60 samples at 44.1kHz, and 90,240 90 samples at 192kHz at the other end of its range..
I would have imagined a number in the hundreds. Maybe @John_Siau could comment, as this is a DAC2 HGC in my rack.
Equivalent to being another foot and half (or less) few millimeters away from someone/something with which you are trying to synchronize audibly/visually.
RayDunzl
Central Scrutinizer
Riverview FL
Oops.
Miscalculation recalculated above...
maverickronin
Midwest, USA
DACs by themselves don't usually have latency issues but it doesn't come up once you get into stuff with builtin DSP like AVRs or some active speakers.
I think it should be measured on those devices, but not as many people here care.
tomtoo
Germany
I
At the end a lot of systems run with software.
20ms for real time music is fu** much.
But how do let's say dsp's in speakers add to this? For me thats a absolutly legitim question. I enjoy that gamer perspektive.
zermak
Italy
I am sure you can test it yourself somehow, empirical way, with some audio and video sync tests (ala guitar hero test to compensate for monitor lag; better with high framerate video).
I am using EqualizerAPO with a FIR filter and 131k samples and I can't spot any problem while playing games (or for that matter on those youtube video I was talking about even if I found only 60fps video and my monitor is a 144Hz).
LTig
Europe
Ah...
RME specifies latencies between 0.024 ms and 0.14 ms for the AD and DA chips in the RME ADI-2 PRO, depends on filter type and sample rate. The total latency is higher by 11 - 23 samples, resulting in 23 samples at 44.1 kHz = 0.5 ms and 36 samples at 192 kHz = 0.2 ms. So nothing to worry about.
MRC01
Pacific Northwest
It's actually an interesting question from a theoretical perspective.
Mathematically ideal D-A reconstruction (Whittaker-Shannon) is symmetric which requires looking ahead. Put differently: each sample has a "ripple" that influences samples both before and after; the "sinc(t)" function. The worst-case scenario is a single full-scale sample with zeros before and after it -- the single-bit impulse often used to compare different filters. Here, the ripple from this sample decays to -96 dB (16-bit resolution) in about 44,000 samples in both directions (forward & backward) in time. So theoretically, at CD quality (44-16) the DAC must have at least 1 second of latency for the ripple to decay into the noise floor.
That said, this latency is purely theoretical and much longer than is needed in practice, where DACs use different methods (like delta-sigma) which gives results nearly the same as the above mathematical ideal, but with much less computation and latency. In practice, latency from most DACs is in the microseconds or less so it's a non-issue. However, some DAC chips provide alternative filters having lower latency. A DAC designer might use one of these for near-real-time applications like recording and monitoring.
PS: my DAC uses the WM8741 chip which provides 5 digital filters. At 44.1k sampling the latency of these varies from 7 to 47 fs. I believe that's "femto-second" which is 1e-15 second. This is less than a single sample which is about 2.3e-5 second.
To the extent anyone is looking at me to measure, Audio Precision software is not real-time and fully predictable. Nor does it have a simple latency measurement. I have tried to work around these to get some numbers for some reviews but they are not high confidence values.
q3cpma
France
Hi !
I'd first optimize the overwhelmingly important software side: do you use a CONFIG_PREEMPT=y kernel with a high CONFIG_HZ? Maybe with a less throughput oriented scheduler like MuQSS, PDS or BMQ. Knowing how and when to use nice/ionice is a good idea too.
dasdoing
Salvador-Bahia-Brasil
is this even possible on windows?
versus666
versus666
I'm happy to see my question gave so many answers and wasn't ditched. I love that open mind, even is some were a bit off. I admit I was a bit hasty and forgot to talk about other time sensitive uses like interactive music reproduction, with a keyboard or a guitar. And about any time delay effect of the various filters used by the DACs chips. I'm glad it was discussed nonetheless.
Yes, Xanmod. Nice and ionice are know and used when needed.
So it seems the general consensus, even if, for once, it is not really measured is that the delay between the event in the computer (not screen) and the production of the analog signal exiting the DAC is well below anything a human can perceive.
Thanks you !
