Fluffy
- Joined
- Sep 14, 2019
- Messages
- 856
- Likes
- 1,426
Hi! I'm new to this site so I'm hoping I'm posting to the right forum.
My question regards the relationship between non flat frequency response and nonlinear distortion. To my understanding, nonlinear distortion is a deviance from linearity, meaning that the output signal does not correspond perfectly to the input signal. In that case, a frequency response that is not flat will definitely change the output signal so it doesn't match the input signal.
Let's say, if the frequency response of an amplifier is such that frequencies above 10khz are reduced by 1 db, then a complex signal entering it, such as music, will come out the other side changed. A peak that should have been of some value given the gain of the amplifier, will be at another value because the high frequency component of the signal is relatively reduced in level by the amplifier. And thus, it will be distorted relative to the original signal.
Am I missing something here?
