PaperBoat
My JBL 305p MKii's sell sheet telling this ↓
What does it mean?
staticV3
What does it mean?
The 305p MKII has two input sensitivity settings: -10dBV and +4dBu
At -10dBV you can input a maximum of 2.0Vrms (6dBV) before the input clips.
At +4dBu you can input a maximum of 8.0Vrms (20.3dBu) before the input clips.
PaperBoat
PaperBoat
This means if I push 2Vrms in -10dBV input it will give the same SPL as 8Vrms in +4dBu input? +4dBu is less sensitive than -10dBV?
FrantzM
To
What does it mean?
To sum it up in a digestible fashion:
The - 10 dBV is for consumer type components. A regular preamp, DAC, etc ... These are usually single ended, i-e they have usually RCA outputs, but you find more and ore output with 3.5 mm jack... these are most often stereo. So -10 dBV is for those, output at max, 2 Volts.
The +4dBu is for "professional" items, these usually have an XLR or TSR as connectors. They typically output more voltage than consumer products... Sometimes up >10 Volts. These are also balanced. The 305 inputs are balanced but you can use Single Ended (RCA) through the use of converters.
If you are going to use these with consumer type equipment, say a consumer preamp or DAC or AVR with pre-out then you need to :
  1. Switch to -10 dbV:
  2. Use a RCA to XLR converters/cables such as these:
or id you are going to use a Professional Preamp/Mixer/DAC or Balanced ones...
  1. You switch to +4dBu
  2. Use cables such as these:
or those that are also balanced but TRS
Hope it makes sense.
Peace.
Oestepa
the Quick Setup Guide advice to connect consumer equipment with unbalanced outputs to the ¼" TRS input of the speaker using unbalanced signal cables.
  • JBL_3_Series_MkII_Quick_Setup_Guide_English.pdf
MrOtto
So you can use RCA to TRS or TS cables? TS is for unbalanced.
Edit, manual says to use 1/4" TS plug:
