JBL 4312SE Studio Monitor Revealed at CES 2017
watchnerd
Seattle Area, USA
http://www.avsforum.com/jbl-4312se-studio-monitor-revealed-at-ces-2017/
http://www.jblsynthesis.com/productdetail/id_4312se.html
SYSTEM TYPE: 3-way Bass-reflex Monitor
LOW FREQUENCY TRANSDUCER: 12-inch (300mm) Aqua-Plas®-coated Pure Pulp cone woofer (1200FE-8)
MID FREQUENCY TRANSDUCER: 5-inch (125mm) Polymer-coated Pure Pulp cone midrange (105H-1)
HIGH FREQUENCY TRANSDUCER: 1-inch (25mm) Magnesium/Aluminum Alloy dome tweeter with waveguide (054ALMg-1)
RECOMMENDED AMPLIFIER POWER: 10-200 Watts RMS
FREQUENCY RESPONSE (-6DB): 44Hz - 40kHz
SENSITIVITY (2.83V@1M): 90dB
NOMINAL IMPEDANCE: 6 Ohm
CROSSOVER FREQUENCIES: 640Hz, 5kHz
ENCLOSURE TYPE: Bass-reflex via Front-firing Port
INPUTS: Five-way Binding Posts
FINISHES: Black Woodgrain with Black Cloth Grille
DIMENSIONS (H X W X D): 23 1/2" x 14-1/4" x 12" (597mm x 362mm x 305mm)
WEIGHT: 55.5 lb (25.2 kg) each
RayDunzl
Central Scrutinizer
Riverview FL
Do they come in left/right pairs?
RayDunzl
Central Scrutinizer
Riverview FL
Sometimes I see pairs that make me go WTF. These, no, I suppose.
I'm not sure I'd be a fan of the horizontal mid-tweeter layout, though. Seems wrong.
FrantzM
Same here :) ... Interested though in the 4429 ..
JBL needs to put some order in their lineup. They're all over the place.. Recently "discovered" there was a 4306 monitor ... Don't know if it is from the Pro, Synthesis or just JBL lines :confused:
RayDunzl
Central Scrutinizer
Riverview FL
watchnerd
watchnerd
Seattle Area, USA
Might make more sense in a studio with it laying on its side on the monitor bridge, which would give the tweeter and mid a vertical arrangement.
watchnerd
watchnerd
Seattle Area, USA
I thought the 4306 was a Japan only model.
RayDunzl
Central Scrutinizer
Riverview FL
RayDunzl
Central Scrutinizer
Riverview FL
watchnerd
watchnerd
Seattle Area, USA
It may be a Japanese model, but in these days of modern times it's only a click away...
Yeah, I know. I was tempted to get one a while ago just based on the looks.
But the specs are pretty ho-hum:
format 2-way bookshelf type
Used unit
LF
200mm diameter pure pulp cone woofer
HF
25mm diameter aluminum - magnesium alloy diaphragm compression driver + high density horn
Impedance 6 Ω
Allowable input 150 W (music)
Output sound pressure level 89 dB (2.83 V / 1 m)
Frequency characteristic 50 Hz to 40 kHz (-6 dB)
Crossover frequency 3.2 kHz
Dimensions (W × H × D) 278 × 460 × 300 mm
weight 12.0 kg
Dynamix
Nörway
I think I can get by with my 4319's...
Dynamix
Nörway
Are you kidding me?
Those things suck. You should sell them.
To help you move on to something better, I'd be willing to take them off your hands as an act of charity. ;)
Yeah, they sound like utter crap. Feckin' junk. :D
RayDunzl
Central Scrutinizer
Riverview FL
