JDS Atom amp - volume knob light not turning off ..anyone notice this?
w00ds153
Noticed volume knob light does not turn off when volume knob is turned all the way counter-clockwise and clicked into off position. Can anyone else confirm this on theirs?? Thanks. The only way I can get the volume knob light to turn off is to unplug the amp itself from the back.
W
w00ds153
Had to turn on and off about 10 times ..maybe it needs to be broken in. Still sticky.
soundwave76
Finland
I had this when my Aton arrived. This trick of tapping (more like hitting) solved the case for me.
restorer-john
That's terrible. If the relays they are using tend to 'stick' with the tiny currents in that thing, the relays are crap or they aren't turning the coils fully off.
Seriously, banging the casework? Brilliant. What a joke.
daftcombo
I had it the first time I tried to turn it off.
With the amount of chinese products I've been using in the last months, that was no surprise.
I turned it on again and off and the light went off too.
jseaber
Someone sent me a link this morning to this thread, suggesting I chime in.
First, thanks for the feedback. I agree this behavior is unexpected. Sorry in advance for the long message.
The relays are produced by Kemet, rated for 2A. We have used the exact same line of relays in other products for years in various circuits (gain control, muting, and system power). I was just as surprised as everyone else when the behavior appeared while prototyping Atom Amp, so I spent considerable time studying the circuit, trying different relays (all with the same behavior), reviewing application notes, and reaching out to the relay manufacturers themselves.
The circuit is simple: a constant 12VDC regulator feeds the SPST switch of the Alps potentiometer to make or break relay coil current. A diode protects the coil.
If you're reading this message board, I do not need to explain to you that relays are an old mechanical technology. We chose to use a relay to toggle amplifier power because doing so permits a front mounted switch. The same level of performance without a relay would have required placing a 2A DPDT switch on the rear side of the amp. Customers over the years have complained about rear mounted power switches. Thus, Atom Amp's power is relay toggled.
After a relay stuck once in prototyping, I handed the board to a coworker and asked him to switch the amp on/off repeatedly. He came back after 100+ tries, convinced I was crazy. Nevertheless, I spent weeks seeking to understand the behavior. Relay contacts can stick under strong magnetic fields, or due to micro-arcing from high currents through the contacts, or from a sudden bump (i.e., relay dropped or hit). I was already aware of these basic possibilities--we've observed gain and muting relays stuck in the wrong position in various boards over the years, always resolved by cycling the relay once.
Anyway, the relay controlling power in Atom Amp was not being hit or dropped, and there was no extreme magnetic field, so this left micro-arcing as a possibility. Micro-arcing happens when strong inrush currents cause the relay contacts to temporarily stick. Thus, I delayed release of Atom Amp by two months to implement soft-start circuits in the AC/DC regulation circuits. Atom Amp's +/-15VDC rails slowly ramp up from 0V to their final value, minimizing inrush currents.
Still, we've observed about 1 in 200 Atom Amp relays stick in final Q/C. The vast majority of Atom Amps never exhibit a stuck relay contact. For those that do, allowing the contacts to stick, then power cycling several times is generally all that is required to ensure that the power switch works as intended there on out. Once the contacts break-in, they tend to be reliable. I placed a tip in the Instructions PDF in case more break-in was required.
The Atom Amp on my desk was one with a stuck relay when first powered on. I've been trying all week to replicate the behavior. It only works as expected. The good news is, relay sticking is limited to initial use of a small number of amps.
To be clear, I do not intend to downplay or otherwise justify this behavior. Yes, the power relay can stick when Atom Amp is new. When a design has Achilles' heel, people focus on that.
Although 99.5% of customers never experience a stuck power switch from Atom Amps, I am actively seeking advice from outside engineers. It's a challenge, as a single prototype is unlikely to prove consistency of relay operation. Even 100 prototypes is not definitive. And such an enhancement must also not compromise Atom Amp's leading performance and FCC/CE compliance.
Thank you all for the support!
W
w00ds153
Don't hit the Atom too hard, it might split! ..and we all know what happens when you split an atom ..especially if your headphones are plugged into it. You hear the deepest bass and crystal clear highs for a couple of seconds and then everything turns to dust (yourself included).
Thanks so much for the honest post John. On this, have you tried to put a small cap right at the relay contacts? This was standard practice to stop the arcing.
jseaber
Thanks, Amir. I believe I tried a capacitor on contacts months ago and observed similar consistency as with the soft-start circuit (which we kept). Will double check. It's frustratingly difficult to reproduce this behavior. By the time I get my hands on a stuck relay, it tends to self resolve. I may have to disable soft-start to exacerbate.
tired_guru
It's been reported by many users in JDS ATOM AMP MEASUREMENTS thread. But for most of them it only appeared once at the beginning and never came back. It's been like after trying to power off the amp it clicked but the white LED light was still there, so I guess it was still on. I just simply turn it on again and off, and it was all fine this time. After this one incident it never happened again so this is not like a problem at all. Some people suggested it might be some residue of flux after production or some oxidation on switch connectors that's been scraped after first use but now we know this is about stuck relay contacts.
restorer-john
So is this the final board below?
Are you relay switching the AC input, the half wave rectified AC prior to the 317/337 regulators or the regulated outputs of the 317/337s?
Why not post an excerpt of the power supply front end and we can help.
jseaber
@restorer-john - Yes, that is the v1.00 production board. Your synopsis is correct. I've attached relevant portions of the AC/DC stage if you want to take a look (part #s and other circuitry omitted).
By the way, the same relay contact placement has been used for years now in Element, except with a latching relay. The separate reset coil must provide more release drive than the non-latching counterpart.
Edit (May 9, 2019): I believe this quirk has been mitigated through a simple BOM change (different 1uF caps; no change in performance). As there are thousands of Atom Amps in the wild and more in inventory, it will take time to push the change and verify through observation.
glassmoon
Would it be OK to leave volume knob at desired level and just turning the Atom's AC on/off (via switch on the power cord) - I feel like constant turning of the knob will cause the wear and the classic "volume potenciometer issues" like cracking and imbalance over the time. Thx.
RayDunzl
Central Scrutinizer
Riverview FL
I thought crackling pots occurred with lack of use.
Oh well.
glassmoon
Oh well.
i'm no expert. just experienced few knobs get worse over time in this category of devices (amps a dac combos around 100-200$). guess if it's quality one it should work for years. just asking...
solderdude
The Neitherlands
Using a different brand/type relay perhaps ?
JohnYang1997
China
From my knowledge those pots are getting worse because of the dirt getting in. Anyway the alps pots are really good and will never have this sort of issue. Tho the channel balance isn't perfect.
glassmoon
thx for the replies.
i'll be using it then as intended by jds - using the pot as a on/off switch.
