...Looked at the post below showing the values and Q, but it has 17 points to adjust and I'm limited to 10.
For a compromise suggest use free Rephase as @QMuse did and set them seventeen PEQs, now to reach a ten times PEQ compromise shift the "Bank" dialog to "02" which means you get seventeen new clean PEQs into bank-02 and task is then use only ten PEQs to make graph as smooth flat as possible, those ten times PEQ you end up with is in reverse so remember to shift + to - & - to + when you set them into the 10 times PEQ unit or reverse @QMuse seventeen PEQs using the "Tools" dialog before the ten times smoothing task ..
