Kareoke Setup
Rod
Ipad-Tidal or Youtube kareoke-Chromecast-Topping 30-P.A.(with mikes)
Rod
Rod
Well after playing around with it for a few days, its about what I expected. Sounds a little tinny, but the separate units are light enough for the ladies to set on the floor or on stands on the side of the tv and small enough to fit behind the tv when not using it to sing. Sounds better than the sound bar I had and helps me hear the vocals better when I am watching tv. I plan on using a remote on-off switch for the PA because its 6 feet to get to the back of the PA;). Anyway,wife is having fun with it,which is what matters. Merry Christmas.
Rod
Rod
Added this old JVC karaoke player and it all still works. Will use it to play cd's though as component out looks bad on modern TV's. Makes a good cd player. Next will be a slim sub to fill out the lows(dont have the room for a normal size sub).
bigx5murf
I recall seeing a Karaoke amp while thrift shopping a couple months ago. I think it was a Yamaha KPA-501, I was a little tempted to pick it up, but could find next to no info on it. I recall it having A+B speaker outputs, and a lot of preset EQ settings, a couple of mic jacks, a couple of analog inputs.
My wife's also a fan of karaoke. She's been using the wii and 360 ktv games. But she wants Japanese, Korean, and Chinese songs, and I haven't figured out how to do that. Foreign games won't play without modifications, which when done hamper the devices other features. It's too bad, but video game consoles really do the karaoke thing well. Unfortunately the games lose support over time, and song selection becomes too limited.
Reactions: Rod
Blumlein 88
When doing karaoke you can find many songs on youtube, vimeo or some others. I don't know how many Japanese, Korean or Chinese karaoke tracks are on youtube, but I'd bet there are some. Just search for the song title plus karaoke.
You'll need to be able to output sound from a computer and do this real time.
RayDunzl
Central Scrutinizer
Riverview FL
I will only participate in Karaoke if I should (which is unlikely) once again find myself in the neighborhood of 35.7° N, 139.7° E
Blumlein 88
Come on Ray. Would you only listen to Mozart if you are Vienna?
bigx5murf
I'm already setup to do that, have PC HDMI to AVR. I also have 2 XLR mic inputs courtesy to behringer umc202hd. Thing is the games are more interactive, with scoring and other mini goals. Making it more like, and in some ways better than hourly retail ktv. But the best games have online streaming for song libraries, and those will most likely just shut down some day, just like they have for the versions of the games on previous generation of consoles.
My parents had a device with thousands of instrumentals in midi format, and you pick them with codes from the remote, just like at a real retail ktv location. It also had a scoring system, but I think it was a random number generator.
Rod
Rod
Chromecast hooked to the topping d30 works well for youtube karaoke. Cheap too.
Rod
Rod
During my search for a machine, I seen hard drive karaoke machines pre-loaded with Asian music. I dont personally know how good they are. But in the Philippines karaoke is still very popular. Machines are everywhere, even my in-laws have one. 5 peso for two songs.
helloworld
Well, if you know a little bit about Chinese, you can buy from taobao, there are a lot of karaoke machines with 4TB preaload songs.
bigx5murf
I can't read Chinese, and can only speak it somewhat passably. My wife is literate, but she's electronics illiterate haha
Looking up some of the devices you described on aliexpress, wow they're pricey!
Rod
Rod
More like Tokyo.
Yep, thats why I went the youtube route. Song quality is hit or miss. I did see this one though without music for about 250.
http://ace-karaoke.net/karaoke-player/standard-hard-disk-karaoke-jukebox.htm
helloworld
Looks like its cheaper with more features.
I have one karaoke system in my house, but it costs me about $2000, including 2 bmb csv900 speaker, if you want $200.... that wont sound good.....
bigx5murf
It's just a music server, still needs amp and Mic preamp to work. Sky's the limit for your budget there.
The biggest issue with karaoke seems to be the lack of good UI, software, and library. Which of this device works well, Could fill the role.
