Kef Blade one Meta - How is the sound ?
verdun
That should apply to all published graphs/illustrations.
Kal: if you will indulge me. I have a room size nearly identical to you with two openings to adjacent spaces: 4.9ft wide behind the speakers, plus 7.8ft in one long wall. I am likely to buy Blade 2.
What happened if you moved a Blade closer to a wall than 1m/39ins? Thank you in advance.
BTW it is wonderful to see comparison data 'using @pierre’s fantastic site here' (via post #49) of Blade 1 and Blade 2.
Kal Rubinson
Industry Insider
NYC
They are there now. About 35" from tweeter to sidewall.
q2klepto
For fun I'm going to attempt to concoct a "Great Value" or "Wish" Blade One Meta.. Aka LS50 Meta sitting on an RF92 placed on top of a 30" platform
Using a minidsp 2x4hd to eq, align and set crossovers
Could be interesting lol
Altho I don't think I can crossover at 350hz from the RF92 to the Metas..
Pearljam5000
It's cool cut like this
Descartes
Kef Blade one Meta seems to be a loudspeaker where they have thought of everything .
The crossover frequency for the uni - Q driver seems to be set at 350 Hz . The baffle is about 36 cm wide .
Using the formula by Troelsgravesen for baffle stepcorrection 11600/36 = 322 Hz , this means they have thought of having a wide enough baffle to go down almost to the rooms transition frequency , without using any eq. This is only one of many factors Kef have thought about .
Maybe some of you have heard the Blade 1 ? How did it sound ?
Read more here :
So simple inside and so expensive!!
Descartes
Picture of room set-up? Because I found absolutely no problems with width, space and size in all the auditions I've had with the Blade One and Two. I've only listened to them in a rather large room, though.
Other than that, I agree about the Kii BXT. That thing is just insane and is on a whole other level for kick, impact and dynamics in the bass range. Closed design has probably little to do with it, the acoustical benefits of many drivers and cardioide combined with timing and oodles of power is more likely imo.
SBIR cancellations are so destructive to sound quality it's not even funny.
How large is the room?
hvbias
US
Has anyone else heard them compared to Kii 3? I have to say Kii 3 really built up my expectations and I was certain I was going to love them, hearing them didn't real live up to what I was expecting.
Descartes
Updated link: https://www.spinorama.org/?sort=date&reverse=false&search=Blade
