KEF LS50 Meta Review (Speaker)
Newman
The English Can Do It.
Mnyb
Sweden, Västerås
Hmm nice :) i get an Osborn computer feeling here , I’m very intrigued by KEF nowadays and would consider them
But I’ll wait untill there is meta coaxials in the R range ?
Eetu
Helsinki
Thanks! 1-2k wiggles aside as good as I was expecting.
Can anyone explain if/how the efforts to minimise diffractions (rounded cabinet) show up in the measurements vs the R3 with its sharp edges?
Tangband
Sweden
Two subs that you can use as stands and you end up with a nearly perfect speaker. And this to a not to bad price.
That genelec sub fits nice fr9m the optics for me.
https://www.audiosciencereview.com/...ef-ls50-meta-review-speaker.25574/post-871554
Even better would be buying the Kef R5 instead. Then you have a crossover at 400 Hz and you can play much stronger with less distortion.
A 5 1/2 inch coaxial such as the one in ls50 meta is gonna struggle if you play loud and crossover at 80 Hz .
@amirm What are we seeing with the impulse response? A single cycle? Is this supplied by the Klippel's DAC and amplified?
This is a computed impulse from the frequency sweep. Inverse FFT is performed post computation of sound field and elimination of the room. In other words, there is a lot math involved and some accuracy may be lost causing those small wiggles. I do have an in-room, unprocessed version:
Maybe I should post these instead.
tomtoo
Germany
A 5 1/2 inch coaxial such as the one in ls50 meta is gonna struggle if you play loud and crossover at 80 Hz . View attachment 145934
If i have two subs i see no reason why i should crossover at 80Hz?
Tangband
Sweden
With a waveguide ( as the uni-q unit is functioning in R3 ) you dont need a rounded cabinet. Theres gonna be minimal diffraction.
With waveguides for the tweeter you dont need rounded cabinets.
restorer-john
That explains it. Thanks. :)
DACs_Lover
With 2.1 channel system, how do you guy separate a low frequency to sub? Kindly name the hardware thank you.
thewas
@amirm What are we seeing with the impulse response? A single cycle? Is this supplied by the Klippel's DAC and amplified? Because there's a bunch of cycles in 3 distinct (pre-ringing-like) groups in the leadup to the impulse itself. Is it a series of impulses where you have just captured one or a single one?
Also, what is the cabinet made of- moulded plastic?
The front baffle is some rigid polymere and the rest is MDF(!) with damped inner bracing making it feeling and sounding very dead/damped at a "knocking test".
YSC
In Europe average apartment size is 50m2. Size vary from 35-75m2 in over 90%. Houses are rare in cities that exist for 600-700 years or more. With apartment of 75m2, you get living room about 25m2 at best. Kef LS50 meta is quite enough. If you add a sub, you will easily rattle neighbours glassware.
That’s where very small subs utilising wall gain like the KC62 and genelec 7040 shines. Yes they won’t have near enough juice for a house living room but for <20m2 rooms they are overpowering already
DSJR
Suffolk Coastal, UK
"I was not a fan of the original..."
I purchased the LS50 after reading all the rave reviews people gave it on the internet and was thoroughly disappoint with it. Nice to see that I wasn't the only one that was not a fan. Wish I had returned them within the return period, but missed it. Oh well, have since added EQ and now they sound much better to me.
Speaker Toni did an excellent video comparing the LS50 to the LS3/5a. This comparison is accurate. Use headphones. His LS50 had the same tonal character as mine do. With the miniDSP 2x4HD I made my LS50 sound like the LS3/5a in the video by reducing the mids a bit and boosting the top end a bit.
Apologies here but WHY ON EARTH would you want to make any speaker sound like an LS3/5A? This latter was designed from the outset to reproduce distortion and hiss in a BBC OB van and accurate music reproduction had nothing whatever to do with it - the BBC had far better monitors available at the time for that purpose, although nothing for very high level monitoring back then. By the way, 3/5A's were NEVER used with grilles off - made the deliberately engineered hf fizz even worse ;) Falcon make the closest version of the original and that's the mid 80's version with upper mid 'quack-n-screech' Stereophile have tested two versions of this make now and the second issue does seem slightly better but still rough as a badger's backside really - it'd be annihilated here!
YSC
I use built in high pass from the 7040, but if your sub don’t have one, you either have a mini dsp to set those cross over, or you have a sub with low pass where you match and measure it with the roll off slope of your main monitors, I think normal AVR having the sub output channel does the same thing
