BrokenEnglishGuy
- Joined
- Jul 19, 2020
- Messages
- 1,941
- Likes
- 1,163
+1I have to wonder if age is a factor, because I notice younger people like myself tend to complain about the hiss more, or at least notice it.
The serie 83xx is dead silent.It doesn't sound like you want to listen, or fully understand. The hiss was nothing coming from the MOTU, it's a completely silent DAC. Genelecs are known for hissing, and the hiss was present even when there was no source plugged in. Ergo, the hiss was inherent to the Genelecs. This is a common feature of actives regardless of their input, and there is a thread on this forum that categorises them by a hiss list.
It's the Genelcs, full stop. Now you can either believe me when I say they hiss, and it's up to you whether it bothers you or not (and it did me), or you can just keep ignoring it, but them's the facts.
Interesting. I'm going to set a mic and do a recording off the tweeter to see / hear what happens.Maybe, I'm not sure. Genelec's have quoted specs for hiss at a specific distance, and some people are just better able to hear it than others. I spoke at length with Genelec about it, and they concluded that the 8030C just wasn't suitable for me, as I was sensitive to the hiss. Many who find the Genelec hiss offensive end up liking the Neumann KH series, like the 80/120, as those are virtually silent unless your ear is very close to the tweeter.
That's why they suggested The Ones could be an option, as you can turn down the internal amp a lot more via GLM than older models.
Is it perhaps where you have them attenuated or the hiss is coming from a source or something in between.I don't like using that term unless it is true. The quoted hiss specs for the newer GLM variants are indeed lower compared to the 8030C, but it ain't silent.
I would be more interested in someone telling me the results of turning the speaker internal volume way down in GLM, however. Would perhaps sell me on Genelecs again in the future.
Hang on the 8050b's have A/B amps where the 8030c's and D amps. Is this the issue?
I can tell you about GLM internal digital volume control. As much as I can hear, there are no audible worsening of the sound between 0 attenuation and down to - 40 dB . And Im a very critical listener. This volume regulation is according to Genelec done after the dsp crossover. And the noise floor is still low at -40. The processing in GLM 4.2.0 are made with 64 bit floating point resolution and the volume control are made with applied dithering.I don't like using that term unless it is true. The quoted hiss specs for the newer GLM variants are indeed lower compared to the 8030C, but it ain't silent.
I had planned on upgrading this year to the 8350. They have D amps. If there is a hiss it'll drive me nuts.I had mentioned that they would hiss with only the power connected, so it was an inherent hiss which Genelec confirmed, saying that 'dirty power' affecting the hiss was nonsense.
That may very well be the issue. Seems Class D amps are far more likely to hiss than class A (Neumann use class A) and would need more work to mitigate it.
I ain't younger but I am obsessed with hiss and noise.I have to wonder if age is a factor, because I notice younger people like myself tend to complain about the hiss more, or at least notice it.
No hiss from my speakers with my ear to the drivers and that's my unreasonable standard. It has not always been so.No hiss at 2m from my 8350s, in a very quiet room.
8050b have the A/B chipamp tda 7293 , the 8030c have class D integrated tpa 3118 and the 83xx series seems to have infineon mosfet class D designs with lower noise.Hang on the 8050b's have A/B amps where the 8030c's and D amps. Is this the issue?
The hiss is so low at 0 ( full volume ) or -40 dB, - its not an issue .And the hiss decreases in volume when you put it down that low as well?
Ofcorse we are all different.Maybe not to you, but we're all different. As long as the hiss decreases as you go that low down from 0dB, then it would be worth a try in the future for me. If it stays the same, I'm going to remain very wary of them. That's why I'd like a precise answer on this issue.
