Near Field 2 meter distance and below -> LS50 Meta with subwoofer.
Anything else KEF R3 with subwoofer.
I think that's especially important in a smaller space. It also means that the Metas would make a better center channel than the R3, b/c they will sound the same place either horizontally or vertically. The alternative is to have a two foot tall vertically placed R3 center channel on the floor (where else could you put it?) beneath your screen. I don't think that would sound very good.
R3 behaves the same, no? Aside from the asymmetrical aesthetics, a sideways R3 is still a better outright performer if the space allows for it.
although, in the real world it's not that straightforward of course. just using your setup as an example, I'd probably get another pair of LS50 Meta's simply because keeping L/C/R identical can make your life easier when it's time to apply DSP. Assuming you have room for it, the "spare" could be used as mono surround back.
I bought the R7 for my bedroom-pc XD, 1.65m triangleI may be a little weird, but I just purchased a pair of R3s for nearfield desktop use....
I think is not about ''clarity'', is just another Frequency response, depending of what you prefer and listen, you are going to like another.You have all the measurements you need here for the Meta and R3 so you can use those as a guide. But please do go listen to both yourself then decide. When I listened to the Metas and R3, I definitely prefered how the Metas sound, even without a sub. It was in a medium room, maybe 40 square meters or so. Sitting around 3 meters away, volume was cranked and it was loud. Higher than 85db is my guess. Dont even start to think that the R3 sounds like a Meta with an additional woofer, it is not. The Metas have better clarity and not as dark as the R3. You have to listen to them for yourself.
I'd love to hear that head to head with some Kali's. Should have better on axis response compared to the Kali IN-8 V2 that I use, just wish they made a powered Kef R3!
I actually went "backwards" from (cheap) active (JBL 305 MKII) to passive. From my reading of the measurements the R3's closest competitors are the Genelec Ones. Even after factoring in an amp they're also 2 to 3 times more expensive depending on if you go for the 8341 or 8351.
I'd love to have a pair of 8351's, but I decided to keep a more reasonable budget.
Maybe its a trade?Yeah, they are quite the expense. I got my 2.1 used, so it was half price for the 8260 pair and half price for the subwoofer... I'd also argue that in some ways, perhaps especially if it's just a two channel system, the 8260 might be better due to the wider dispersion and deeper extension if I'm reading their off axis graphs correctly.
For a lower priced nearfield setup I honestly like the Phantom Reactors though the perception here is them being lifestyle speakers. Napilopez measured them and they are quite even handed tonally, and have great off axis response... I also like that they follow equal loudness contours somewhat with bass: You can still hear it at low volumes and it's great.
How loud can the KEF LS50 Meta play with out distortion if they are crossed over at 100Hz with a sub?
Safest bet is to use two subs and cross over at 140-150.This is how I roughly estimate how loud a speaker can be played with a crossover in place, others can chime in if my logic is terrible. I take the distortion measurements at 86 and 96 db or whatever I can find if it's at Soundstage for example and see where I need to crossover to minimize the worst distortion. Also, as we know THD is not very audible in the bass frequencies but my thoughts are more along the lines of the speaker probably being close to it's limits if distortion is spiking and remember IMD distortion is a bigger deal with 2-way coaxials so the higher we cross them over the less excursion from the midwoofer and therefore less IMD distortion. Anyway here are Amir's distortion measurements for reference:
Now you can see the 86db level is already pretty good and a 100Hz 2nd order high pass will have it below 1% THD and be no problem at all, this is also loud enough for many people already. Now at the 96 db level the LS50 is definitely more stressed and approaching its limits and a 100Hz crossover will help but it will be around 3% distortion at 100Hz and I'm not sure if the cone excursions would still be high because I don't really listen that loud. Just based on the measurement I would be more comfortable around 120Hz for the crossover if I regularly listened in the 90+ db range at my listening position. With a 100Hz crossover I think you'll be fine around 85db at your listening position but not a whole lot more. Another good way to approach this is to simply set your crossover and listen at your loudest levels and see how much cone excursion you're getting, if you can barely see it moving like me then you're good but if it's moving in and out wildly then it's most likely producing a decent amount of IMD distortion.
My setup is Kef R3 + a pair of Rythmik L22s. I had the R3s first, otherwise I might well have gone with the LS50s. I expect they would be great paired with the LS50 precisely because the subs can cross as high as 200Hz. OTOH, R3 + L12s may actually be cheaper than LS50+L22s.Safest bet is to use two subs and cross over at 140-150.
Why not R2C for the center?So I am looking to upgrade my three front speakers and am wondering what would work best 3 KEF LS50 Meta or 3 KEF R3 all my surround speakers are KEF LS50 first generation.
Also our sofa is only 9 feet away from the front speakers and listen at moderate volume maximum 85db for movies.
Here is a comment I read on What Hi-Fi which I know is not very scientific!
"It looks like the Metamaterial technology really works. These new KEFs sound so much cleaner and more sophisticated than before, particularly at higher frequencies. The Meta make the excellent R3 sound congested and ham-fisted in comparison, and that’s a real shock."
Any recommendations?
