exm
- Joined
- Sep 21, 2021
- Messages
- 267
- Likes
- 225
I'm really a fan of coaxial speakers and always liked Kef speakers. My next speakers will very likely be the R3 Meta.
I just wonder what difference people would hear between the R3 Meta and Reference 1 Meta.
The Reference has a deeper cabinet, 30hz higher crossover point than the R3 and a higher quality and stronger build.
Both have about the same frequency response, really low distortion and about the same bass extension.
Will the Reference 1 Meta still sound better? What am I missing?
I have a lot of experience with Kef speakers. In the Reference Series they use much better drivers, and the cabinets are also build/tuned differently. If you care about crossover quality differences (I don't), there's also that one. I have personally tested the R11, R900 (predecessor of R11) and Reference 5 and I can tell you there are very clear audible difference. The Reference 5s are night-and-day better than either one.
I have tried the R3 and R3 Meta (my rear surrounds) and I feel that the R3 Meta are more open compared to the non-Meta. Does that make the R Meta better than the non-Meta Reference? I guess I would need to try the Meta R11s vs my non-Meta Reference 5s. But this I can tell you: the Reference 5s have a much tighter and deeper LF over the R11s.
