- Joined
- Mar 1, 2020
- Messages
- 479
- Likes
- 854
Now, seriously, it is great you did the blind test, however hard to do. You have to consider the validity of that test, also, because it is not a double blind test, as I understand, because you and your wife were the test subjects and administrators at the same time.
Everybody here is taking your test at face value, just because you got the result that speakers sound the same, which might be the expected result here, and it might be a different story if you found that you liked the more expensive ones.
One other thing you need to consider is which pair makes you more happy and what the price difference mean to you both. We, humans, are visual animals and rely on other senses to form our perception of the world around us.
On the other hand, even if you found that R11 do sound better, you would have to decide if that SQ difference is worth the price difference...
