KEF R3 in a nearfield setup - amp pairing
Hi there,
Which of you are using or have used KEF R3 in a nearfield setup? I already got a pair in my living room and I am considering buying another pair for my work desk (they are deeply discounted now).
I am wondering what is the cheapest amp I can get away with not to compromise sound quality. I have a loxjie a30 on my desk but I am afraid it's not exactly up to the task.
The alternative I am considering is going the genelec 8030c route and not have to worry about amp pairing.
Any experience with this?
T
In terms of...?
Not enough power? High noise/distortion? Lack of features?
First, identify what's troubling you, then the answer will be clear.
Well,
those are fair questions. I am slightly concerned about power capabilities and more concerned about SINAD. But I don't plan on listening louder than 80-85dB from 2m away.
T
Try EigenTakt based amps. You can switch input buffer off.
Well,
I do have a purifi based amp in my living room and it's great. But I am not spending another 1500 Eur for a desktop setup amp :D
Thanks for the input though.
Harryharryharry
I have the r3.
I originally powered it with Hypex nc252 which was good, lots of power.
I then replaced that with topping pa5 which felt like a big sound quality improvement.
I'm powering it for now with the aioyama a07, which does very well for £80 and gives good sound but has some hiss and is definitely not up to the pa5.
If you're buying a speaker as good as the r3 I'd say do it justice and get the pa5.
Topping support is responding and fixing and problems you may or may not have so I don't see that as a big problem.
tifune
Well,
What's the SINAD of your room?
YSC
Hi there,
Wonders what's the discount price on them, in HK they are still like $2200 a pair
maverickronin
Midwest, USA
I have Kef R3's on my desk.
I started with an Aiyima A07 as a temporary measure while waiting for a Buckeye NC252MP. I didn't really notice any difference, but I wanted to keep everything balanced for maximum resistance to ground loops so I didn't mind spending the extra money.
Buckeye doesn't have an NC122MP model, but if you're in Europe, the Audiophonics NC122MP would be a good choice.
The Topping PA5 would be perfect if it was reliable.
The Topping LA90 is more money, but doesn't seem to have the reliability problems of the PA5.
