KEF R3 meta Measurements
Streamc
It's similar to the ls50 vs ls50 metas. The adjustment to the crossover point and the tweeter level are likely to yield the biggest audible change between the OG and meta models.
The directory is unchanged with between the R3 and R3 meta. No longer is there a broadband low amplitude rise above 2 khz. The 3khz peak has been tamed. The early reflections are now almost perfect on the R3 meta. This will account for the largest audible difference. Who can say if the other improvements can be heard. Pretty much need double blind testing to know for sure.
This shows what i am saying. Keep in mind the original kef measurement for R3 was not measured the same way as the new metas. Amirs measurements align more with the differences shown in the meta white paper.
The relative improvement in linearity between the mids and highs is your answer
Why adjustment to crossover point is significant change? It can be anywhere. But resulting frequency response matters. I mean what the difference in crossover point if frequency response is seamless? I do not see any crossover joint.
Kachda
NY
It can have an impact on distortion and directivity. Directivity will be captured in the spin, but not distortion
MacCali
Looking back at nuyes posts, he was referring to the compression in bass region specifically. Something a sub will fully negate.
I find it interesting how often people add a sub to their system, and note how much more full, expansive and larger the sound becomes. Must be something to that.
Agreed. I am planning on adding subs to my room even with the issues I am having, but I am going to get duel driver design like the Kef kc or svs micro 3000 cause my other issue is rattle. If one works with no issue I’m going to probably grab a second sub as well. Even though I’m pretty sure one sub will already overload my room
Pudik
Agree fully, but only if the sub is well dampened. Otherwise sounds will climb one over the other and the general sound becomes muddy and undefined.
Pudik
I like your high-brow attempt. Get you a set of R3s (old model) for about 500Euros each and add two subs. With some background in speaker building I would say there's nothing more to be desired. I had it all, esoteric drivers, magnetostats, huge horn loaded monitors very much like, maybe even better than JBL's M3, the middle range 3-way etc pp.
Ha! FINALLY! Someone who likes my highbrow approach...thanks for the advice. At one point, i was tempted by the R3s, but they still left me undecided. They remain are under consideration, though. P.
Pudik
Hi,
I measured the KEF R3 meta loudspeakers this time.
These speakers have just been released, but I was able to get a pre-order sample (a pair) from an audiophile in Korea.
Impedance
View attachment 266011View attachment 266012
Frequency response
I measure HF responses using a 5ms window gating.
Therefore, the crossover frequency of this speaker was located lower than I could measure, so I could not use the 'Merging Nearfield + Farfield' technique.
It has a similar LF roll-off to its predecessor.
Here's a comparison of 'ported vs sealed' responses.
(This was done with nearfiled measurements, with baffle step compensation applied).
Directivity
View attachment 266015View attachment 266016View attachment 266017View attachment 266018
Wow. That's really cool.
I'm noticing a huge improvement in the 15~20k compared to before.
On the outside, it looks like the exact same product as its predecessor, but the directivity definitely seems to be a step up.
While this may not be important to all users, I can't help but admire KEF's passion and skill in achieving performance improvements despite the seemingly identical design.
(Perhaps it's a fine-tuning of the lemon squeezer on tweeter?)
Beamwidth
View attachment 266019View attachment 266020
It looks as complete as anything you'll see in this price range.
(In South Korea, it's currently available for around $1,700 to $1,800).
Polar plot
View attachment 266021View attachment 266022
This loudspeaker shows almost perfectly smooth attenuation, not only in the front, but also in the sides and back.
Total Harmonic Distortion
I am representing THD relative data as CHD.
This is the percentage of each HD component based on the average SPL from 200 Hz to 10 kHz.
View attachment 266023View attachment 266024View attachment 266025View attachment 266026
You can hear a very clean response at 85dB SPL and even at 95dB SPL.
It's flawless.
Multitone test
View attachment 266027View attachment 266028
Multitone distortion of -40 to -50 dB were measured.
I tried removing the measurement signal below 80 Hz and measuring it.
This was done to see how much the effects of MD from the woofer's high displacement motion and ports could be reduced when used with a subwoofer.
And if anyone remembers, this product also had the "shadow flare" issue that was featured in Erin's Audio Corner.
So I measured how much the MD was changed by this as well.
(The effect on FR can be seen below).
MD for each SPL.
View attachment 266031View attachment 266032
Despite the increase in output, there is very little increase in Multitone Distortion.
This is a strong defense against distortion.
Compression test
This test was performed with Multitone.
It shows a compression of only 0.5 dB even at 96 dB SPL.
Very powerful performance.
Here's a look at compression testing from the other side.
These were performed at 0.1 m and 1 m, respectively, and measured with a sine sweep.
View attachment 266034View attachment 266035
We can see that the response of the woofer increased with the increase in SPL at 45Hz.
This means that the internal air pressure along the port did not remain linear.
In other words, above a certain sound pressure, the ports in this speaker lose a little bit of their effectiveness.
(All SPL values are based on output at 1kHz @1m)
Grill test
The grille is affected by a very high Q value.
Shadow flare
I measured the impact of Shadow flare, which we introduced in EAC.
(I don't own this loudspeaker, so I wasn't able to push the part very hard).
You can see that there is a dip centered around 1 kHz.
(Pressing in the Shadow flare will correct this).
Finally, the FR deviation comparison between the two samples.
A very personal thought.
KEF's precise directional control is truly amazing.
Its predecessor was good enough, but it's even better than I expected.
If I had to pick a downside...
The bass is weak.
Also, due to the compression at high SPL, I think it would be a bit too much for me to enjoy a movie without a subwoofer.
Of course, I was just nitpicking because it was so great. :)
(I envy the owner.)
Cheapest I can find that is $25. With this multifunctionality Kef are adding, the value proposition gets even better. :p
Perhaps the voice coils can do double duty as a toaster too (with apologies to Tim Cook)?
Looove this parallel, eloquent discussion
Pudik
I have no idea how many degrees of openness a live event must have...
I can imagine that if an instrument is on the left and the singer on the right, I think he should remain in the same position even when listening directly from the speakers (therefore voice and instrument shouldn't invade the whole scene otherwise they denaturalize the rendering).
I don't know if I explained myself well, it's not easy with the translator.
I love the Kef sound and like any other brand I believe a little compromise should always be there... hard to find the perfect speaker.
I also liked Sonus Faber Sonetto 2 a lot, but I like 3-way speakers too much and Kef is one of the few I can afford in this price range.
In about 1-2 months the new Meta series will also be available in Italy, I will certainly make a direct comparison by taking mine to the shop to listen together, if it is worth it I will change, this cannot be excluded, otherwise I will keep mine for at least one year.
Thanks a lot See you soon.
Well, we're having a dilemma, haven't we we...
Then what are we to do when wanting realism? For, when in performance, musicians are constantly on the move showing off not only musical skills but acting out the pre-programmed show, be it a rock concert, opera, theater, broadway show,etc. Opera, for example, has fundamentally changed in the past 30 years. In the past, the singers just stood there like statues and sang. Today, this is not enough. You have to also be an actor, and preferably, a good one. So if one listens to live recordings, the movements of the musicians have to be recorded, too. This is why I fully agree with Toole when he strongly advocates multichannel music recordings. Studio is another cattle of fish, though. Here I agree with you when it comes to rock and its derivatives, as well as jazz combos or big band.
Pudik
Thanks. What about the R3 metas, since i could get the R3s, but only used or if new, from small, unknown dealers. The big guys such as Crutchfield with 60 days return, won't have'em anymore. P.
Pudik
And, yeah, amazon also has them, but used. I m kinda leary. Some ppl say the highs are better on the metas, but are they smooth?
Pudik
@Descartes:
It wasn't a 5 euro cable.
It was a special cable, shielded with ferrites, special plugs and various other things.
But I don't think it cost 300 euros either... at most 20 :) nor do I believe that the R3 Metas are worth 2200 euros (in Italy the old 4.5 million lire !!!).
Prices are out of control and if the dealers take advantage, see also the power cables of some models 1000 euros per metre, it's madness.
Returning to 3D as suggested, the only thing is to accept them and if possible make a comparison with R3 and R3 Meta.
Many times these small speaker differences are purely commercial, there are 20 year old speakers that can sound better than these modern ones.
I should do the test within the month of June and then evaluate, of course I'll also tell you my impressions.
If other forum users manage to do it sooner, their opinion will be very interesting.
See you soon.
Wow!!!
2045.4545 lire per 1 €? When I lived in Italy in the summer of 1977, the parity was 'only' 948 to $1. Tempora mutantur, la economia e la stessa
Pudik
OP— Only now got round to reading your well thought-out, intelligent and logical presentation on the R3 Meta. Just wanted to belatedly thank you, and and give you the props you deserve for your allocation of time and resources in providing much needed datapoints
And thanks to everyone else here for the pleasant (but all too brief) escape, and elucidation, and betterment I find these days only here.
I’ve been caring for dad palliatively at home for the last three months, it’s been the worst period of my 46 years. BUT, ASR has been my quiet (and only refuge), so thank you everyone on here, I’ve quietly listened, kept an open mind, and learned so much from everybody. Honest listening isn’t quietly waiting (and preparing) your next rebuttal.”
TLDR Sorry for the above random OT, 24/7 at home with pops can be isolating.
Please be kind to each other. Tell your fam you love them, even if you don’t even like ‘em
I FULLY feel ur pain. My father whom i loved to no end died of Lou Gehrig's disease. Like you, I find this forum a pleasant place with tremendous tech and subjective input, place to learn and muse. And, like you, I beg everyone to be kind to family and friends, cuz they need it, believe me. P.
OldGreg
Original R3s are still available directly from KEF (at least in Canada).
Alexx
Good morning.
Yesterday I listened to the R3 Meta.
I didn't bring my old R3s for direct comparison (I didn't have time to take them apart and load them in my car).
I listened to songs that I know well, the impression was that of a slightly more open soundstage than the old R3 and they also had greater attention and presence of small details in the mid-high range, small nuances such as guitar or violin string plucks and some very small details on the voice and other instruments were certainly more evident.
Despite this I have to say with great amazement that I did not like them.
The main reason is that on medium-high frequencies they were sometimes annoying (I felt like covering my ears with my hands) too strong and present, I can't understand the reason but this was the impression I got.
On the one hand, that little more detail they gave was very nice, but on the other hand, that annoyance that emerged on some medium-high frequencies was unbearable!
How come? the "Meta" treatment shouldn't take away this problem.
On the forum I read that in the mid-high range the Meta series is less present and controlled than the old R3 series, but from the listening test I did I got the totally opposite impression
Could it have been the fault of a wrong match between Electronics Speakers and Cables?
The amplifier was a Hegel 590 and the silver Chord Cables......but as I said, I find the sound of the old R3s warmer and less aggressive in the mid-highs.
Another option is that the modification of the Crossover of the R3 Meta has emphasized too much this medium-high frequencies.
The shop told me that a customer with direct comparison (R3 Meta and non-meta) preferred and bought the old R3???
I went to buy them but I'm not at all sure, is it the case that I do other tests with another amplifier? (I can bring my Nad 399).
I was very confused, and I'm starting to think that if I put the dirac module on my Nad I can achieve better results, but I'm not writing to say this thing about the module (it's just my thought) I want to stay focused on the Kef R3 vs R3 Meta speech, everything else doesn't matter because a speaker must sound good on its own without adding equalizations especially if it has been updated to have higher quality.
I wanted to tell you about my experience, maybe it's useful or can make some users think......
In the next few days I'll listen again even if I'm less and less motivated to switch to the new model.
Do you have any opinion?
Have you also had the opportunity to listen to the new Meta model?
What impressions did you have the same as mine or different?
Thank you in advance.
HarmonicTHD
Good morning.
You didn’t listen “blindly” and in a different room (dealer vs home) and not in direct comparison to the non Meta R3. So I wouldn’t put any weight on your subjective impressions. Get them both at home, level match and try again.
Beave
Yep, the two biggest confounding variables in your KEF R3 comparison were 1) two different rooms 2) way too much time, meaning you were relying on really flawed memory of what your speakers sound like.
The only way to compare them is the same room, same time.
