Matt_Holland
- Joined
- Sep 3, 2023
- Messages
- 267
- Likes
- 454
Apologies if this comment is a bit unfair, but looking at your favoured music choices, I would guess that this is as much of a problem as the midrange dominant room response you measured. A lot of the music you listen to often sounds terrible on hifi where the compressed dynamics and limited frequency range are fully exposed for what they are.I just re-read my post also and should shed a little more light on the audio quality issue I'm referring to. Using an example might be best. If I pull up Megadeth's Remastered countdown to extinction album - or original CD quality, it is almost unlistenable at even moderate volumes. Its sound like one big ball of shouty distorted sound that makes you cringe. Hard to explain. I play this same album on my JBL Boombox 2 and I can crank it and enjoy the music.. I know kind of a strange comparison but hoping this explains it a little better.
It would also be interesting to know if you have heard a system/room combo that you were really impressed with when listening to your preferred music?
