- Joined
- Jan 15, 2020
- Messages
- 6,905
- Likes
- 16,958
To be more correct Gold Peak is a Hong Kong based company. https://en.wikipedia.org/wiki/Gold_PeakKef’s parent company is GP, which is Chinese.
It is not the exactly same country but has its own government, similar to for example Serbia not being the same with Croatia.Hong Kong is heart of China so no mistake was made
Almost nobody in Hong Kong under 30 identifies as “Chinese”
The territory’s residents increasingly see themselves as distinct from mainlanderswww.economist.com
I know each room is different, but what is the minimum required distance from back wall according your personal experience? Like the absolute first point the speakers start to sound as they should.If you intend to put them close to the wall behind (or if your couch is next to a wall), you will end up with too strong bass and that will mess up the midrange impression. That's one of the reasons i mounted wheels instead of spikes on speaker stands. During the day they are close to wall so they don't get in a way. When kids go to bed, i position them at best sounding spots, away from the walls.
I would also like to have some info on stand wheels if you have the time to write two words. Do you use default stands? Do they come with threaded base so to fit castor wheels?
Depends. If you ask people in the northern part of bavaria, they will tell you that they are franconians and not bavarians.If you ask most people living in bavaria they rather they are bavarians than Germans .
I'll add that I checked mine after hearing about this and they were slightly loose but no issues. I will caution though that on the Lintons the screws have wood screw threads and are anchored in the MDF, making them easy to strip. For those of you (like me) with a penchant for over-tightening screws don't make them "good'n'tight" and you'll be fine.Apparently most Lintons are fine so it's very rare, but if you want to check your screws, always make sure that you don't use too much force, otherwise you might damage the screw holes. They don't have to be super tight.
As an aside I saw that the Emotiva speakers used a metal insert in the front baffle MDF for the driver screws. The screws then have machine threads. I wish more speaker companies did this- a very strong solution with less chance of damaging your cabinets (provided testing confirms it has no impact on sound quality).
Yah, so my plan is to listen for awhile Sunday and then measure a few parameters and then take the midrange out and seal up the sub enclosure for said mid, give the caulking a day to dry and then listen. I will remeasure as well see if anything obvious pops up. I thought about doing one at a time and comparing in mono but decided just do both at once.
I am curious if anyone else wants to see check their mids and see if theirs have properly isolated space. Plug the ports and gently but decidedly push the 8" woofer in and see if there is movement in the mid. @Zvu did not have this issue, nor a loose screw issue.
Did you try the R3s with a sub? Thinking it would temper the fatiguing highs.My decision - I sold the KEF R3 and decided to go for the Lintons. I can just go on listening to music on them without any fatigue.
