BrokenEnglishGuy
- Joined
- Jul 19, 2020
- Messages
- 1,942
- Likes
- 1,164
Only at 100%~ its audible the distortion in lower bass.The red line is 100db, so it’s at 100db. Same with canton.
If you plan canton and kef at 100db you hear distortion in bass from kef and in treble from canton.
Kef has more extension but at 100db it doesn’t matter as you will be annoyed by that distortion than what is audible.
While in the mid range (around) 1% is enough to be audible, and you cannot fix a distortion in the mid range but you can add a subwoofer to the mains speakers
Because the R7 have more extension also mean the R7 are playing the lower notes louder, you can Tame down these lower bass in order to match the spl from canton, you are going to reduce the distortion in the lower bass with the KEFs.
Is not fair compare the distortion in the lower at 93dB vs 86dB.
You don't need low distortion in lower bass, for example this is a 15'' subwoofer 68 Kg
As you can see the distortion at 20hz@109dB it's 12.5%, that's extremely low for sub.
