Kernel Streaming, ASIO, WASAPI... and music players (Foobar, JRiver...)
daftcombo
daftcombo
So, basically, you tested the audio signal coming directly from the speakers, right?
But what about testing the output signal coming directly from the DAC-output (balanced or unbalanced plugs)? It would be nice to compare if the same increase in distortion can be seen on Focusrite's RCA/XLR plugs too.
You are right, I didn't think about it though it seems obvious. I will do that.
daftcombo
daftcombo
Boy, it was even uglier than expected.
First : Wasapi (event) 16 bit
Second : ASIO Focusrite driver
daftcombo
daftcombo
Other information that could interest you:
1) No difference in distortion between Foobar2000 and JRiverMC 24.
2) In Foobar, no difference in distortion between Wasapi (event), Wasapi (push).
3) In JRiver, slightly higher distortion with Direct Sound than with Wasapi or Kernel Streaming or FlexASIO. See pictures.
First : Wasapi (note: Kernel Streaming and FlexASIO are at the same distortion level)
Second : Direct Sound
(for those two measurements, the level was set differently than in the previous post)
4) In Jriver, with the Focusrite ASIO driver, same crap than with Foobar.
daftcombo
daftcombo
In REW, I use the same Focusrite ASIO driver for the input.
Perhaps this shit is due to using the same ASIO method in two different softwares?
Veri
DS looks less 'bad' than I expected. This is at 100% Windows volume I suppose?
Seems like you can easily get away with using plain directsound.
daftcombo
daftcombo
100% or 80%, I don't remember sorry.
zermak
Italy
Interesting investigation.
So if I may ask are you using DS with 1:1 frequency rates or a fixed value on Windows sound output and so Windows does the upsampling? I am curious to know if with 1:1 (or maybe integer ratios) the performances stay the same or get worse.
daftcombo
daftcombo
In Windows, my Scarlett is set to 16bit/44kHz, and in Foobar2000 and REW too.
zermak
Italy
Thank you and what about messing with the output rates in DS? I am curious to know how bad (and if) is the Windows resampler.
And the bit depth? I guess it will not affect the quality at all and Windows will just pad it in a higher bit depth rather than dither it (like modern DAC do if I remember correctly).
I've read the article on archimago blog about software volume but he doesn't talk about the above and it would be nice to get some info about it for me to set Windows audio properly with the lowest loss in performance in DS mode (on a technical point of view cause I doubt I can spot to the differences while listening, mainly with my audio setup).
daftcombo
daftcombo
I will try to do some more testing with various bitrates, but I think it it very dependant on the soundcard/DAC.
zermak
Italy
Yes, sure but as long as you use the same cards we can evaluate if there are benefits in using 1:1 rates and so on :)
BYRTT
Denmark (Jutland)
@daftcombo, @zermak
Think studying below visual should show why pro and audiophiles run WASAPI or ASIO and for DS most set their Windows sound system to 44,1kHz because thats what most web stuff run at, when SRC is used notice the amplitude and phase distortion (grey phase curve is how minimum phase should have looked for that particular amplitude response) plus all that hash/grass that grows up in GD graphs, when ASIO is used notice how distortion graph is lovered to insane low levels because test is run using soundcards SPDIF I/O (no ADC/DAC in loop) and GD graph gets simply a perfect thin line verse the hash/grass at HF using DS.
For daftcombo's trouble shooting i would try switch to another USB cable and then another USB port and see what happens, if that doesn't work then try analyze if interface can perform well on another computer or another interface can perform well on the trouble computer.
daftcombo
daftcombo
Ok, I just noticed that REW was running at 24bit.
So I went to Windows control panel
and changed the Focusrite setting from "16bit" to "24bit"
and did a sweep in Foobar with Wasapi (event) 16 bit again.
Guess what? I had the same shit exactly (distortion) that I had with ASIO in Foobar!
What to conclude?
daftcombo
daftcombo
And same shit again with Wasapi (event) 24bit in Foobar + 24bit in Windows.
Hmm perhaps it is when you have 16bit for AD and 24 for DA, or the other way around, that shit happens?
Edit: With 16bit AD and 24bit DA it is ok. With 16bit AD and 24bit DA it is ok.
With 24bit AD and 16bit DA, it is ok. With 24bit AD and 24 bit DA, not ok.
Can someone explain that to me?
REW seems to always run at 24bit for recording (according to the status bar).
Edit 2: Well, just found the answer to my question. It applies to my soundcard:
Applies to: Scarlett (whole range)
When using the WDM driver, 16-bit or 24-bit modes can be selected from the Windows Sound panel (right-click on the device and select Properties > Advanced to find this setting). However, this setting has absolutely no effect when recording using the ASIO driver, which users should always use in DAWs, due it's its low latency and increased performance over WDM (Windows' own audio driver).
The audio stream captured from our hardware is always 24-bit samples. These samples are not altered or processed in any way by the driver when recording. The Windows audio control panel may say the device is in 16 bit mode, but the ASIO driver bypasses the Windows audio system, and is therefore not affected by this setting.
Therefore, using 24 bit depth in your recording software, while using the ASIO driver, is still 24 bit when recording/creating, where 24 bit actually matters.
zermak
Italy
@daftcombo, @zermak
-cut-
So basically DS is alright to use in 1:1 ratio with the frequency of the audio the program uses; let's say games and other standard stuff like system sounds ahah and maybe sufficient even with movies, but it is actually crap (as we already knew) for audio processing considering the bad results.
I only use DS in games (and maybe a few uses WASAPI shared but I am not sure about it) but I let Windows resample it at 4x; I guess I will stick with the 1:1 unless you have some proof that Windows DS isn't that bad with (integer) multiples of the frequency used.
Veri
@daftcombo, @zermak
So the big question. When using 44/44 or 48/48, is the 0,002% distortion audible in any way over ASIO?
andreasmaaan
@daftcombo, @zermak
That's fascinating, thanks. Do you have a source for it or is it from your own experimentation?
BYRTT
Denmark (Jutland)
For this new loopback test seen below it looks stay 1:1 because there is response changes in first row and exploting bloom into GD row, that said one cant know if supported Windows driver for my card is well written code but at least it looks perfect written when runnning in ASIO mode and WASAPI is probably same as ASIO but REW dont support WASAPI.
Probably not but we stay free of the GD HF exploting bloom and get automatic shifting track material rates (audiophile) :) by the way such hash/grass i also noticed running Win10 native UAC2 driver for ASUS U7, where DS driver from ASUS had not that grass so probably its good thing check systems with loopback test. That said as told above one cant know if supported Windows driver for my old PCI card is well written code but at least it looks nearly perfect written when runnning in ASIO mode.
Welcome, test is my own simple loopback test in Win7 and using that soundcards SPDIF I/O's feature gives less noice in loop to reveal Windows SRC differences than using its ADC/DAC loop.
bennetng
Hi, I am the author. In my own digital loopback tests Windows SRC indeed has higher distortion when using "non-divisible" sample rates. Here are some of my tests with the soundcard's master clock at 48kHz. I am not saying it is audible but just in case if you are curious.
You can also try the WASAPI shared mode plugin as well. It handles volume (specifically the limiter) better than the bundled DS module in my machine.
https://www.foobar2000.org/components/view/foo_out_wasapis
Here are some test files to try out. Be careful when using exclusive mode since the limiter in Windows mixer is supposed to be bypassed and a.mp3 should clip relentlessly until foobar's volume control is at -12dB.
https://www.audiosciencereview.com/...y-of-software-volume-control.5922/post-172865
When using non-exclusive modes, take a look at the system mixer's volume of individual apps and make adjustments to suit your needs.
zermak
Italy
@BYRTT Thank you for the report, very usefull and indeed revealing. I will stick at 1:1 in DS mode :D
@bennetng I have read it but maybe I missed it or forgot about that part (probably the latter) and so thank you for the reminder.
About volume contol I've just found that my stereo amp prefer a 1Vrms input through its RCAs in so is there a way to fix it in Windows considering that at full volume (0dBFS?) the Khadas TB I am using has a 2Vrms output? And again; will ReplayGain affects the output too? I guess it will so maybe I can use ReplayGain to adjust all my library to output 1Vrms changing the 89dB target volume of ReplayGain itself and then rescan my library. Just wondering. Or maybe the inner volume control of the Khadas TB available by installing its USB drivers is the way to go? (note for the above: I just played the two audio files you suggested and the file a.mp3 (which is made to clip) keeps clipping while adjusting the Khadas inner master volume but it doesn't, as you said, if I lower the foobar volume (or using ReplayGain which suggests a -19.15dB gain; and for completeness a -7.11dB gain for the b.mp3 file).
And again out of curiosity, but maybe I am going OT, I used the Windows volume at 76% in past with my Asus Xonar DX sound card because it seems (by Uni Xonar driver developers) that it could cause volume fluctuations in certain situations (source).
I will sure give a try to the WASAPI shared mode and the audio files and I will report back waiting some tips for a possible solution of the 1Vrms output (which will benefit the O2 headphone amp too probably).
