Kii THREE controller
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Isn't that enough!Its what I have done my entire life!
Keith_W
Melbourne, Australia
Well, i'm intrigued. I am after a programmable universal remote. What DOES it do? Can you program it? Output by IR? Wifi? Bluetooth?
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
It is purely for the Kii THREE loudspeakers, it enables you to use them as a complete system within themselves just add digital and analogue sources .
RayDunzl
Central Scrutinizer
Riverview FL
I looked at the picture and thought it a remote.
Then I saw the ports.
Then I looked for a description, since none was provided, and found none.
So, in the end, I guess it's a volume knob, an input selector, maybe a function selector for the speakers, a wired digital waypoint between sources and the speakers.
I did find another picture:
For now I'll assume it's a digital representation of an industrial design that may or may not exist physically, yet.
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
bit here,
The Kii CONTROL will offer three additional inputs for the Kii THREE:
Coax, Optical and USB (up to PCM 24/384kHz and DSD64/DSD128),
The inputs are located on the backside connector panel as shown on picture 1.
Please note that the aluminium top cover will have a dark grey finish in serial production.
The Kii CONTROL boasts lossless volume control inside the DSP of the Kii THREEs remotely adjusted from the Kii Control. The volume knob also offers mute or dim functions and manual power on/off (standby).
The Kii CONTROL also has IR remote capability, preset functions plus additional functionality accessible via a software menu on the OLED display.
A dedicated input button (labeled XLR) will switch to the existing hardware input on the speaker, which you can continue to use as Analog or AES input.
RayDunzl
Central Scrutinizer
Riverview FL
I'm not a bad guesser.
Sal1950
The Chicago Crusher
Central Fl
bit here,
Unless I'm mis-understanding something in your description. If you start hooking up other components to it via those jacks, it's no longer really a remote then with all the wires attached to it, is it? :confused:
FrantzM
It remains a remote, definitely NOT a wireless remote :)
Sal1950
The Chicago Crusher
Central Fl
firedog
So if you want remote volume control (not thru software) you need to buy some kind of universal IR remote?
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
The Kii will have their own remote next month , volume attenuation, input selection, and software control, i.e. Latency, boundary and contour filters.
FrantzM
What were they thinking in these days and age? I mean, Digital input, DSP and the whole nine yard and not a wireless Remote?:rolleyes:
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
The remote is wireless , but it does allow you to connect more sources to it.
