Klipsch subwoofer when powered on producing 'boo' noises continuously
nicebar
Bought from Amazon, and told from an unauthorized dealer and refuse to providesupport.
However, customer is following the Kliptch brand name, and from a reputable Amazon platform, - how can customer easily tell which one is authorized, even with trust of Amazon platform, and how can the unauthorized dealer get the product from Kliptch with a resale margin!? This is just absurd.
Don't you think it's either Kliptch or Amazon that be responsible for regulating the market, and eventually it's still essentially Kliptch the company itself to protect and honor its brand credibility. this way you are damaging the Kliptch brand, market as well as trust of customer!
It's still Klipsch product within warranty, and NOT a fake one!
sword
Might be a ground loop problem.
beefkabob
You're not going to hear a lot of support for Klipsch here. It's junk. If it's out of the return window, throw it away then get something good.
Chrispy
PNW
I don't even understand what the OP is saying....so you guys above, mind explaining JWTFIGO?
radix
By "Boo" I assume you mean a low frequency rumble.
As @sword said, likely a ground loop or bad shielding on the cable.
Try plugging in to the same outlet as your preamp.
Make sure you are using shielded RCA cable.
If those don't help, call/email Klipsch.
MeZoX
some subwoofers have a "ground lift" switch , try that if its available in your sub
Teeter
Janesville, WI
@nicebar Did any of the suggestions work? Did you try calling or e-mail Klipsch. Most major manufactures will try and work with you. You don't know unless you try Klipsch. Most times, one has to go through the mfg and some stores may have a 30 day exchange program.
