Krell FPB 350 mcx
RayDunzl
Central Scrutinizer
Riverview FL
A quickee look and see...
Bought 9 years ago used, no rebuild, no repairs, no faults. Serial number indicates 2005 build date.
Left monoblock, approximately 5W/4Ohm tone, loaded by the speakers:
Not great...
Left Channel.
695 more rated watts available, though.
Let's see:
THD 0.012% = -78dB
Noise 0.091% = -61dB
Maybe adjust by 2.5dB since the signal wasn't full-scale, if you like.
Should investigate the inaudible power fundamental and harmonics.
At least the harmonics don't look like some of the very low priced stuff*.
Then again, the speakers distort more than the amp, and the room is noisier...
Yup.
THD 0.21% = -53.5dB
Noise 3.66% = -28dB
*recent modern low price example
RayDunzl
RayDunzl
Central Scrutinizer
Riverview FL
The only thing looking off is the high level of 60 hz and harmonics in your results.
Could be the "test" wiring.
A 30ft XLR to a naked XLR plug with three 18" alligator jumpers to the amp terminals and, maybe, ground.
The whole area over there is a rats nest.
RayDunzl
RayDunzl
Central Scrutinizer
Riverview FL
Hmm...
Amplifier powered but on Standby....
And I see this - black
With microphonics - peak red
And I'm reading the EMF of the woofer of the speaker... or possibly the panel too...
Looks the same as above with the amp completely powered off.
Power on to standby bump (inaudible).
Amp fully powered on, no signal, preamp off, with inaudible standby -> ready turn-on bump:
Amplifier ready idle, add idle preamp - preamp power bump (inaudible) and ah-ha.
The source of additional noise and high frequency slope.
With the amplifier fully on, no microphonics visible from the speaker. Making noises looks same as above.
Blumlein 88
So if I didn't misunderstand, you are getting hum from the preamp?
RayDunzl
RayDunzl
Central Scrutinizer
Riverview FL
Measurable, inaudible.
With preamp full volume, about the same measure, no audible hum, ear to woofer.
With the pre volume at minimum:
I'll have to try straight from the DAC sometime.
Not that I'll use it that way, but...
MediumRare
Chicago
Looks to me like the stats in the first chart are 0 to 45,500 hz. Can you run 20-20k to see what the distortion and noise % are?
Maybe with laptop to DAC direct to amp, no preamp?
RayDunzl
RayDunzl
Central Scrutinizer
Riverview FL
And microphonics from the speakers?
When the amplifier is off, yes.
No amplifier feedback trying to maintain zero volts, to absorb/counteract the back EMF from the speaker.
I can run it as far to the right as you like. The amp spec says
I can only measure to 96k, though.
But later.
Dinnertime.
I made enough pocket money on YMZ19 this evening to pay for a couple of steak dinners. Short at 27747, close at 27732.
Wow. Volatile tonight,
Oh well. Don't be greedy, they say.
RayDunzl
RayDunzl
Central Scrutinizer
Riverview FL
Back by popular demand!
One Night Only!
The usual REW measurements at an calculated estimated measured 4.72V across the ouput for 5W into the 4 ohm speaker load.
Using PC REW Measurement Sweep @ -25.9dBfs -> USB -> Focusrite Clarett 4pre ch7
-> internal routing -> coax left channel ->Benchmark DAC2 -> XLR -> Krell FPB 350 mcx -> jumper clips -> XLR
-> Focusrite ch 2 ADC -> Ch2 USB out -> REW analyzer
Frequency Response and Phase:
Distortion:
Impulse Response:
Group Delay
Step Response
Idle noise signature
And 5W tone
RayDunzl
RayDunzl
Central Scrutinizer
Riverview FL
I guess at least it didn't embarrass itself too badly, so, still good to go.
Estimated 5W SINAD at 80dB, based on the third harmonic.
RayDunzl
RayDunzl
Central Scrutinizer
Riverview FL
Uh...
The preamp sits on top of the Equitech, and the amplifiers flank it.
Just maybe that isn't the best place for it to reside...
RayDunzl
RayDunzl
Central Scrutinizer
Riverview FL
No audible noise of any kind at all from the speakers at any time or volume setting.
My room isn't totally silent, but the system seems to be within that constraint.
