Hello,
I am in the process of reverse engineering a HDMI audio extractor to build a HDMI audio capture card. The extractor is USB powered and has two identical SOT 23-5 buck converters that provide 3.3 and 1.8V.
I could not identify the parts but the pinout and circuit match, for instance, Texas Instruments TLV62569 or this one:
I am not an experienced DIYer, but what i see most often in this sort of small audio devices are LDOs, that seem to be all advantages: low noise, few components, etc.
I am very intrigued of why they have used buck converters, that go with one inductor each (see picture) and a small army of ferrite beads and loooong arrays of capacitors, i assume, to do the necessary filtering. The device works with as little as 5V 0.5A input, so I don't think it is related to efficiency or high currents. As mentioned, the device is USB powered (5VDC), there isn't a large voltage drop to 3.3 and 1.8 Volts.
What are the reasons one would chose a buck converter over a LDO for a small USB powered digital Audio/video device?
And most importantly, as i don't have much space in my design, i wonder what are the chances to screw it if i forget about the buck converters and use a couple of LDOs?
thanks for any comments/advice.
HX1001 Datasheet - Synchronous Buck DC/DC Converter
Hexin Semiconductor, Stock #:923593, Datasheet, equivalent, pinout, replacement, pdf, complementary.
datasheetspdf.com
