Legacy Focus SE
murraycamp
I am in the market for a speaker upgrade and may have the opportunity to buy a pair of these used. I could not find any reported measurements. I would appreciate hearing about anyone's experiences and opinions of these speakers.
They will be for a 21'x30' room and powered by (ultimately) Hypex NCore amps (probably nc500 based). I primarily stream Qobuz hi res files throughs a CCA into a miniDSP SHD. Other sources are occasional RB CDs and some vinyl as well.
Thanks in advance for your help.
ahofer
New York City
I auditioned a pair of these. My subjective impression was they were very easy to listen to and had a big speaker feel, somewhat on the “warm” side, perhaps not as detailed as the more expensiv KEFs and ATCs I heard the same day. I could imagine myself living with them long-term-and fatigue potential is one of my main audition criteria.
They seemed to punch well above their weight, price-wise ($8k?). I heard them with Krell, Anthem, and Primaluna amps,I think (dealer was hyperactive with amps). The tube amp didn’t seem like a good choice, but it has weird frequency response.
I ended up buying Harbeth SHL5+, but listened to them on another day.
M
murraycamp
Thanks!
Ron Texas
If the price is right and what you really want is floor standing speakers then it's a go.
Sal1950
The Chicago Crusher
Central Fl
Bill's built a number of versions of the Focus loudspeaker, don't know if I ever heard any.
What I do remember is everything I heard from his lines were very impressive sounding.
Can't remember which ones he had at the Tampa show last Feb, one large floor stander and a stand mount in separate room.
Both revealed a Class A sound IMO
I've always had great regard for Bill Dudleston as a speaker designer.
If the price is right I think I'd grab them, they should fit your room size very well.
John Atkinson at Stereophile measured the Focus 20/20 model way back in 2004
https://www.stereophile.com/content/legacy-audio-focus-2020-loudspeaker-measurements
geek101
California, USA
I have met Bill in person without knowing who he was. Was thoroughly impressed on how well he answered some of my questions.
That aside I did listen to a lot of speakers @ RMAF 2018 and what stuck me was the value for $$, the detail towards engineering excellence and comittment to providing great sound using science by Legacy Audio. They are one of few vendors that insist on good room correction.
I listened to Focus SE , the Focus XD and Aeris. I would go for the larger ribbons and bigger drivers. They have Caliber XD that you can custom order with bass section powered.
When budget constrained I would go with Caliber XD (save money on amplification) and later add a sub.
I would characterize the sound has fatigue free, getting those larger ribbons and special drivers does lower the distortion and room correction is important.
For me the alternative is a pair of ATC SCM 19a but they still need a sub.
Good luck. It is very hard to find honest speaker.
M
murraycamp
I appreciate the input. Unfortunately, the opportunity passed and they were no longer available by the time I expressed serious interest. Not in the cards. Back to the hunt.
Maybe some Zu Omens. I hear they have effective electrosmog filters. ;)
