LG USB-C Type Earphone jack adapter(3.5mm) EBX64331001 Simple Review
thin bLue
Reviewer
USB-C 타입 이어폰잭 어댑터(3.5mm) EBX64331001
I bought this myself.
Let's find out what I got with 10.77 USD.
Under Asio4all 16 bit 192 kHz
90k
22.4k
DC-90k Fr Textbook Flat
DC-90k Multitone
Not so impressive...but, under 11 USD (Including Shipping)???
Under REW 32 bit(?) 384 kHz
90k
22.4k
Under REW 32 bit(?) 48 kHz
90k
22.4k
Under Windows 32 bit 48 kHz Chrome WEB Tone generator
Hell G Maybe 32 bit and 48 kHz Ext(Chrome WEB Tone generator) OUT 0 dBFS 22.4k.PNG
But, I found that, There is No 3rd party ADC review of this category of product.
I don't like that kind of thing happens.
Did not work.
DID WORK!
Under Aiso4all 16bit 96 kHz
Enough low fi for Dolphin's talk (Dolphin's range 20 Hz to 150 kHz)
Under Aiso4all 16bit 48 kHz
Enough for JK's phone call(Girls Talk on smart phone)
Clip starts at 0.240 Vrms
Hard clip @ 0.241 Vrms
IMHO, Nice tiny DAC and ADC for 10.77.
staticV3
for your ADC tests, did you disable/bypass the dongle's bias power supply somehow? Or did you feed that voltage directly into your signal generator?
thin bLue
thin bLue
Reviewer
No LG inside.
But, You can find LG engraved(?) logo out side.
It's sad to mention old-fashioned Korean companies being weeded out. However, it is inevitable that companies fail to adapt will disappear.
If they had treated the DAP as the key element rather than the smartphone, they could have expected slightly better profitability.
And LG withdrew its mobile division due to business failure.
So, You & I probably won't see "LG inside" for almost forever.:facepalm:
thin bLue
thin bLue
Reviewer
This wasn't a serious test, so I didn't bypass it.
For precise measurement and to prevent damage to the equipment, it would be right to bypass it!
kongkong
It's quite a honest dongle at price. Enough for ordinary consumers' iem.
I have three dongles(one is cheap like LG's) and two headphone amplifiers(including audio interface) but I know I don't have to buy all of them lol.
I believe cheap and honest products can make lifestyle with music for people.
For above reason, thanks for your works and I expect your next work!
thin bLue
thin bLue
Reviewer
Thanks for your warm-hearted comments!
