LG v40 to Chord Mojo
carlslost
I have connected my LG to a chord mojo using high res file the mojo light says the bit rate is only 44. Is there a setting on the LG to output higher bit rate via usb.
Cheers in advance
Veri
The whole thing with Chord DACs is that it uses a "strong" digital filter to oversample your source material to a much higher sampling rate. Why worry about using a low input rate? :)
Jmudrick
Cheers in advance
What playback software? I would think bit perfect mode in USB Audio Player would do what it's supposed to do.
Jmudrick
no software that I know of. can u suggest any.
USB Audio Player Pro is designed to work with external DACs as well as take full advantage of the capabilities of the fine internal DAC in the LG. Works for me.
