Linkwitz LX521.4 - new build and impressions
Joecarrow
Hey all, is the necessary room behind the speakers due to the bass section or the top section (holding the midrange through tweeters)? I'm sure its for both (probably) but was wondering if you could get away placing the top sections a little closer to the back wall (separate from the bass).
Thanks,
Jim
It's both. I've experimented moving them separately, and there are different deleterious effects for each. Moving the bottom section closer quickly reduces the bass output. As it gets within a foot or so of the wall it's a very noticeable reduction in bass. I found that three feet is really the bare minimum, though more is recommended. For the top section you start to get some significant timbral effects, I found it started to sound sort of boxy and indistinct. It's somewhat better if the surface is really diffusive and not a flat blank wall. I have mine in front of a pair of book shelves right now and the bookshelf fronts approach a little closer to the speakers than three feet, but they are open front and full of stuff.
If space is tight then I strongly recommend the LXmini. I've heard them both back to back in the same room and it's quite surprising how similar they sound despite being such different designs. Yes the LX521 does a lot of things better, but it does need the space and in a small enough room the mini wins.
JimB
California
The top and bottom sections need to remain close together.
jeffbook
Columbus, Ohio
Linkwitz covered woofer and midrange separation distances on his website. See this link:
http://www.linkwitzlab.com/frontiers_5.htm
It shows the effect of separation distance on crossover behavior for various crossovers at different frequencies. However, speaker placement within the listening room with regard to distance from side and front walls is still a paramount concern with both the LXmini and the LX521. Suggested minimum distances to walls, speaker separation and room size for the LX521 need to to be heeded for best performance.
JimB
California
With that, one wants to consider the crossover frequency of the upper panel and the woofers (~120 Hz?). The speaker is not intended to be treated as a satellite with subwoofer.
Joecarrow
I’m sorry if I’ve created some confusion with my description of experimentation- yes, the system needs to be built and used as designed. No, it’s not condoned or a good idea to separate them, but you can’t hand me a speaker like this with a DSP that allows easy digital delay and expect me not to screw around with it and measure the results. I’m just reporting that two separately observable issues arise from approaching the wall to closely, and they could just as easily be shown by moving the whole speaker and turning sections off to isolate the problems. Sometimes in order to find the best performance it’s useful to probe the glaring issues and see how quickly they get worse.
jeffbook
Columbus, Ohio
Correct. The LX521 is a full spectrum integrated 4 way speaker system crossing over at 120 Hz..
However, There are instances where a separate dipole bass module can be used in the Linkwitz speaker universe that require proper integration. My current speaker system consists of the LXmini integrated with separate dipole bass modules from my original Linkwitz system, the Orion. Since the dipole modules are freestanding, the integration techniques discussed in the link posted come into play.
I am currently considering building a hybrid system that would consist of the Orion bass modules currently in use with the LXmini along with the LX521 upper baffle with the Seas MU10B upper midrange as used in the LX521 system along with Seas W22EX001 8" speakers (used in the original Orion system....) as the lower midrange drivers instead of the U22REX drivers specified in the LX521 design. A similar hybrid system has been designed and built and is discussed on the Linkwitz user group. In this case, the integration techniques from the link in my prior post once again comes in handy to assist in DIY design.
Siegfried never discouraged such experimentation with his designs. His website and availability of his designs and construction plans can inspire and encourage DIY experimentation under the guise of learning and simply having fun as well as creating a great sound system for music enjoyment.
capslock
How much do the L26 woofers actually move when listening to real music (i.e. not home theater or synthetic stuff) at high but not concert volume (90 - 95 dB at listening position)?
My dealer stood me up on my order of four L26, and there are cheaper and more efficient drivers with nearly the same fs and Qts but lower excursion.
Joecarrow
They can move quite a bit, like I see them moving from my seat. What's remarkable about them is how much they can move without making extraneous noises. I do think that you can have success with other woofers, especially if you highpass them and also use a conventional subwoofer for the lowest notes. The trouble is that you'll need to be able to measure and iterate to get the crossover just right.
mamsterla
They barely move at all. It takes something like heavy synth music to see them move at all. They are really amazing drivers so I urge you to use them in your final build, but if you need to do some substitution, just try to match the parameters. If you want me to play something, I can video it close up. I want to saw that I cross-over my LX-521.4 at 60Hz to my dual Rythmik subs.
capslock
So this is essentially a 60 Hz LR2 or LR4 lowcut? This would make a lot of difference to a 1st order 30 Hz low cut as proposed by SL in the plans.
Adam_M
In my experience, they move quite a bit. Many mm. I'd be afraid to use a driver less robust than SL specified.
More efficient may be a problem, but will certainly require a filter modification. You will also want to make sure the frequency response matches. Running drivers with no enclosure puts a ton more stress on them (through movement) than in a sealed box or even a ported box above the tuning frequency. You also need to consider the physical design. While not terribly critical for the woofers, a relatively open basket may be helpful.
I'd suggest you consider if you have the experience with open baffle speakers and DIY speakers in general before modifying this design. While it isn't rocket science, it's more difficult (at least to me) than a conventional box speaker. I've designed dozens of speakers, and built dozens more from kits. The LX521 is the only one in the lot I wouldn't mess with.
This probably sounds more negative than I intend it to be. Experimentation is at the heart of DIY speakers. You should run the experiment, but don't rule out the need to buy the L26's if the experiment doesn't work. I've had more failed (initial) designs than successes. I learn something from every one.
capslock
Ok, how about XXLS12 then?, either in Peerless or Scan Speak incarnation? They should just about fit without making the V-baffle any wider, they have about 1.5x surface while having 0.83x excursion so a net higher air volumen they can move. Max excursion is given as +/- 28 mm (so the same as L26).
Another option may be to use the two layer L26ROY which higher sensitivity and seems to be overall a better driver than the RO4Y.
These are my options (I either have the drivers or can actually buy four of them - unlike the RO4Y).
Peerless XXLS12 Nomex 830845 (27 Hz / Qts 0.52 / mms 98 g / Vas 119.5 l / 87.5 dB at 2.83V) - this is an 8 Ohm driver
Scan Speak 30W4558T (17 Hz / 0.31 / 135 g / 197 l / 89 dB)
Peerless SLS12 (31.5 Hz / 0.54 / 74 g / 132 l / 90 dB) - again an 8 Ohm driver, max excursion unknown
L26ROY-new (25 Hz / 0.42 / 118 g / 56 l / 87 dB)
as compared to
L26RO4Y-old (24 Hz / 0.27 / 173 g / 46 l / 85.5 dB)
L26RO4Y-new (26 Hz / 0.27 / 160 g / 40 l / 86 dB)
It is worth noting that while the new RO4Y has gained +/- 1 mm of linear excursion and half a dB of sensitity, its already high mechanical resistance has gone up to, from 5.4 to 6.53 Ns/m.
The L26ROY is actually pretty close in parameters but more efficient, has half the mechnical resistance and much lower inductance.
The 30W is way more efficient (especially considering it has an 8 Ohms coil) and also has a pretty heavy cone. I suspect differences in LF extension (fs, Q) will only play out below 30 Hz, which is low cut or room gain territory anyway. Not sure how the soft suspension will play out, but then this is a V baffle, so no heavy air loading.
The 830845 has considerably higher Q and lower mass. Is this going to be a concern?
Adam_M
It all depends on how much fussing with the filters and measurements you are willing to do. There is more than the t/s parameters and physical fit to make this work. You will have to alter the filters to achieve the correct on axis freqency response and it would also be highly beneficial to keep the same off axis radiation pattern. SL says somewhere on his website that flat on axis is required but it isnt all that is required (I'm paraphrasing here). I'd look at other ob designs - like John K.'s no longer available NaO series as well as SL's previous products to find suitable woofers.
I don't think these are ugly. Really nice build. Nice to see the outcome of the Madisound flat pack kit. Seriously considering this build.
magicLX
Germany
The finishing and hiding of cables is the biggest challenge for most DIYers when building them from scratch
With a little help from the pros, the aesthetic resultts can turn out quite nice:
As prefabricated cabinets or as turnkey systems with new low distortion midrange LINKWITZ22MG and cascaded ASPv2.0
Joel Foust
Just an additional review. I’ve owned both the Orions and LX521’s. The LX521’s were way better to my ears. I started with the passive mid-tweeter crossover ASP.3, then tried miniDSP, then built the ASP.4 with through hole components finally returning to the ASP.3. I know some will think it’s crazy but MiniDSP definitely wasn’t for me and the ASP.4 just didn’t image as well in my setup(I’m definitely in minority here I know)??? I got into building class A amps and made the mistake of selling the LX521’s and building some high efficiency speakers. I quickly realized I should have stayed married to the LX521’s and am now making investments to reinstate our relationship. I’ve purchased a Zapco HDSP with much better DAC capabilities so will revisit DSP. If not I always have the trusty ASP.3 that did not go with the sale:). Long story short but nothing I’ve heard at Rocky Mountain Audio Fest or Axpona holds a candle in my opinion. The imaging is insane.
So to talk about bass and need for subs for a second. I mix live sound and generally run subs up to about 110dB at FOH with plenty of feeling in the chest. You will NOT get that out of LX521’s. However, they do have a good amount of bass for audiophile listening in the 80-90dB (say at 8 feet away) range without subs. If you high pass at 40-50hz they will play a bit louder before compressing bass. Dipole bass is very special but definitely not what you will impress your friends with as it just does not pressurize the room in the same way. I selectively ran with boxed subs depending on listening goals and genera. For example electronic music sounds fantastic but adding subs does help the experience. The Seas subs in the LX521 are very special, they have 30mm Xmax and do not bottom out as suspension catches before it hits the back plate. The Vd is something like 1000cc which is more than many 15’s and even some 18’s. In a dipole configuration with cancellation you do lose a bit of bass which this smallish sub makes up for with its extended displacement. The sub is probably the highest quality sub I’ve ever used.
Last point I’ll make is my current high efficiency speakers measure well and sound good and host a great party:). LX521’s didn’t excite many friends and family like my current monsters do simply because they can do much greater than 100dB without straining…. But when everyone goes home I no longer sit up by myself and enjoy the music as I used to:). Maybe I can talk my wife into multiple rooms of audiophile equipment….
tktran303
I’m one of the misfortunate few who move houses every few years (6 moves in 10 years).
I have had monopoles and dipoles and big and small speakers (7L to 100L+ litres).
The upside is that I can tell you that rooms make ALL the difference.
Anyone working in live sound will also tell you that: It’s nice to get a speaker that has flattish frequency response, but EQ is a definite necessity.m
Any speaker designer also knows this- after they’ve completed their tour de force; they hold their breath when it’s exhibited for the first time in a new and unknown environment.
Build listen enjoy adjust.
What are your current high efficiency speakers?
