- Joined
- Feb 23, 2016
- Messages
- 20,771
- Likes
- 37,637
Each of these zip files will open into three wav files. One is labeled Reference, one is A and one is B. These are 30 second snippets of full songs. The originals were from CD so all 44.1 khz and 16 bit.
Either A or B has been thru 8 generations of DA to AD copying. The other is identical to the Reference file. So the 8th generation copy should be the odd one out in terms of sound quality. I decided not to make it a poll. So just put your replies to any you listen to in this thread. I'll reveal which is which in time.
Thought it a good chance to let people hear what 8 rounds of copying sounds like. If you don't hear a difference post that too.
https://www.dropbox.com/s/q8dhhxkjsbaho4w/Ry Cooder and VM Bhatt.zip?dl=0
https://www.dropbox.com/s/mp7b1rj8xekimvf/Phil Woods.zip?dl=0
https://www.dropbox.com/s/v60bqlqdfbcktf4/Jennifer Warnes.zip?dl=0
https://www.dropbox.com/s/xc3g1h887vot4hn/Cowboy Junkies.zip?dl=0
https://www.dropbox.com/s/1vnoquxjisu70zd/Bob Marley.zip?dl=0
Only look at the spoiler after you've auditioned the files. The answers are in the spoiler for each file.
Since the poll is closed here are the answers for each file.
1 is Ry Cooder and V.M. Bhatt B is the copy.
2 is Phil Woods A is the copy
3 is Cowboy Junkies B is the copy
4 is Jennifer Warnes B is the copy
5 is Bob Marley A is the copy.
1 B is the Copy
2 A is the Copy
3 B is the Copy
4 B is the copy
5 A is the copy
So 50:50 split on the first two and 2, 4 split on the third.
I can ABX them all. It isn't easy, but it is doable. I can't do the 4th gen files or even the 6th gen files. I can the 8th gen files.
1 B is the Copy
2 A is the Copy
3 B is the Copy
4 B is the copy
5 A is the copy
