Listening SACD with DMP6 eversolo
Joao Correa
Hi ! Is it possible to listen an SACD Disc with an external dis reader and usb connected to a DMP6 ?
OdysseusG
Nope. Due to the copy protection rules/measures that are part of the SACD spec external optical drives should not be able to read the SACD layer of discs. The DMP A6 can play the DSD files though, if you manage to rip them from the discs- even multichannel
J
Joao Correa
Thank you very much. Can I rip SACD with external optical drive. Do I need something especial ?
bargainguy
You can't use a CD drive to rip SACD.
You'll need a functioning BluRay disc player, a properly formatted flash drive with AutoScript installed, and the latest version of SACDExtractGui on your computer,
on top of an already cumbersome process.
Here's a tutorial from PS Audio:
