Little Bear MC3 XLR & RCA Switch Review
Rate this switcher:
    Votes: 2 1.5%
    Votes: 7 5.2%
    Votes: 33 24.4%
    Votes: 93 68.9%
This is a review and detailed measurements of the One Little Bear (Nobsound/Duok) Little Bear MC3 XLR and RCA switcher. It is on kind loan from a member and costs US $69.99.
I like the large knobs although I wished they had aligned them better. As you see, you can switch between one RCA and two XLR connections:
This is a passive device so no conversion between the types. The box is heavy enough for RCA use but my XLR cables managed to topple it backward. Still, quality is pretty good for such a low price.
Little Bear MC3 Switcher Measurements
Performance with both XLR and RCA in/out was the same as internal bypass on Audio Precision analyzer:
No extra noise either when I compared a direct wire connection in channel 2 and going through MC3 in Channel 3:
Predictably there is a loss in crosstalk although what is there is better than most amplifiers:
Edit: the box does route between XLR and RCA. This causes ground loops though but there is that measurement:
The MC3 device is a simple device that does its job well. It is a great solution to add more inputs to an amplifier.
I am going to recommend the One Little Bear MC-3 switcher. My only wish is that they reduce the number of names they give to their products!
Somerville, MA
someone should put a switcher inside a box with a phono preamp and a dac with a streamer. Maybe some EQ and a volume knob too, and a headphone out.
AndreaT
Commonwealth of Massachusetts
Nice review! However I wonder what happens with the mix 'n match combinations, like XLR in, RCA out. It does not seem that the higher XLR voltage input is decreased throughout the RCA out, and this might be a problem.
RayDunzl
Central Scrutinizer
Riverview FL
From the review:
"This is a passive device so no conversion between the types."
glc650
From the review:
It's advertised as a conversion device though and there are other passive devices that are just for conversion like the Neutrik XLR to RCA device.
RayDunzl
Central Scrutinizer
Riverview FL
You are correct.
RayDunzl
Central Scrutinizer
Riverview FL
@amirm
Can you test the frequency response, assuming there is a little transformer in there someplace for the conversion?
@amirm
I don't think it has a transformer. Here is the frequency response:
AudioKC
Good enough for conversion from xlr to rca for subs. Great review Amir! Thanks.
DesertHawk
Is there a reasonable volume control with a remote that you could add to this to make it competitive with a preamp?
restorer-john
There will be no conversion in this unit. No transfomer and no active circuitry means no actual differential drive to the XLRs. The XLR to RCA probably just drops the cold and connects only the hot.
StuartC
Rugby, United Kingdom
Snap. I use one for switching between my DAC (XLR out) and AVR (RCA out) into my Neumann active speakers (XLR in). The feel of the rotary is direct with very positive detent during selection. Ground loops are evident but can be handled by the speaker setting switches. if anyone knows of an active switcher I'd be interested in knowing who makes them.
Like Ronseal, it does what it says on the tin.
phoenixdogfan
Nashville
I have the version with the outlets on the front. It seems to work very well in my system. It's exclusively XLR like everything in my system, and it seems to have a somewhat lower profile than this one.
