Looking for a straight barebones DAC
iamkimosabi
I’m looking for suggestions on a dac for my powered active studio monitors. I’m mainly looking to record and mix music so accuracy performance is a huge deal. This will be connected through digital outs of my Universal Apollo X6, to my active studio monitors.
Here is a list of what I am looking for:
Accurate
Transparent
No MQA
No HP AMP
No USB
No Bluetooth
Optical IN
SPDIF IN
BALANCED OUT
ES9038pro or ES9028pro
Basically just the best performing es9038pro Barebones dac without any extra features.
I
iamkimosabi
No USB and specifying a specific DAC chip? That may not even exist...
If you can put up with a USB input you don't plan on using there's the Benchmark DAC 3 B.
i don’t need usb but if it has it that’s fine. What I meant was it’s not important. By the way, I thought usb was just an extra feature...dac is normally digital input no? Spdif aes optical?
NYfan2
Netherlands
I
iamkimosabi
What about the SMSL SU-9?
I think it fulfills all your requirements.
It has some functions you don't need but you don't have to use these.
https://www.audiosciencereview.com/forum/index.php?threads/smsl-su-9-balanced-dac-review.16150/
Yeah I would love one of those, but it has way too many things I don't need, and I would like to cut the price down because it has features I would never use. I just need something pristine with the ES9038PRO implemented well, without all the extra bluetooth MQA streaming functionality...don't need headphone out either, just balanced out to my monitors.
Racheski
Chicago
If the DAC is transparent why is the make and model of the D/S chip relevant?
Racheski
Chicago
Because I like it :)
Well it is an arbitrary requirement that will make your search much more difficult and expensive than necessary. But if you insist, here is your answer SMSL SU-8 V2
You won’t find anything cheaper unless it is used.
Jimbob54
Alas I don't believe that's the 9038 Pro. But I agree, no point getting hung up on the chip make or model. Look at the output
Racheski
Chicago
Ah yes good point. It is the 9038q2M. Close enough :cool:
Lorenzo74
Italy, Rome
Accurate
Transparent
No MQA
No HP AMP
No USB
No Bluetooth
Optical IN
SPDIF IN
BALANCED OUT
https://www.audiophonics.fr/en/diy-...xlr-32bit-384khz-dsd-with-screen-p-12705.html
Find one dac more “barebones” than this...
Best
L.
Katji
*Subscribed.* ...With interest. Because I will never buy a DAC with MQA or [probably never] a headphone amp.
Berwhale
free up my analog outputs for summing.
Interesting. Can the monitor outputs be used in the same way as all the other analogue outputs? Is the digital output independant of the monitor output. The diagrams I found in the article linked below seem to indicate that monitor out should be treated separately from the other analogue outputs....
UAD Apollo for summing the mixes best passive summing mixer designed for Universal Audio Apollo by VintageMaker | by Paul Taylor | Medium
I
iamkimosabi
yep, you can route everything through the daw or console software.
reallyoldcob
I've just compared
SMSL SU-9 --> THX 789 (Balanced) --> Focal Clear & HiFiMan Sundara
to
Universal Audio Twin Mk ii --> THX 789 (balanced) --> Focal Clear & HiFiMan Sundara
AND... I found that the UA Twin Mk ii sounded clearly more detailed, nuanced, and lively.
I never thought of the Twin as a TOTL DAC but compared to the SU9 that everyone raves about, I easily prefer the Twin.
