Reggiejackson
- Joined
- Jul 10, 2020
- Messages
- 25
- Likes
- 1
I hope you guys can help me to find some good headphones. I'm using a Marian Seraph AD2 pcie audio interface with Audio techinca 40x which I plan to upgrade on. The stats for the interface ouputs are
I'm currently using Audio technica 40x. Which sound pretty good, very detailed,clear and potentially extremely loud. They are 32 ohm impedance.
I'm using the headphones primarily to play guitar amp sims and to listen to music. I'm not interested in coloration of sound as I would rather have clear detail. I've got my eyes on Massdrop 6xx Senihesser 650 copies which are 300 ohms. I assume high impedance is needed since my line out is 75 ohm?
Also mass drop 4xx, and monoprice m570. Unfortunately all the planar magnetic headphones are low impedance, although I have heard that planar magnetic headphones don't require impedance matching? This is something I'm very curious about
I've been told that I need a headphone amp for this card, but it is already extremely loud, and I don't want any coloration or latency added, although I assume headphone amp are analog? I found a discussion with a user of a Rme hdsp 9632 which is a pci interface with the same types of outs but it does come with a headphone connection also 75 ohms. He tried a e9 headphone amp and said there was no noticeable difference on his 650 headphones except it had the potential to go louder, but it was already more than loud enough. Although I assume a headphone amp would give me lower impedance [ if that is an issue ] and allow me a greater range of usable headphones?
Thanks for any help
- Max. Level: customizable from +15dbu up to +24 dBu
- Impedance: 75 Ohm
- SNR: 123 dB(A)*
- THD+N:
<0,0008% / <-102 dB* - Frequency Response:
0 Hz … 61 kHz - Crosstalk: <-110 dB
Thanks for any help
