As far as I'm aware, the metamaterial plate in the new LS50 Metas aims to reduce a peak in the mid-highs and reduce rearward reflections. Would there be any substantial difference between that and simply EQing the older (and cheaper!) LS50s?
I disagree. I own both the OG LS 50s and the Metas. I've lived with the originals since 2015, and bought the Metas this April.I have the LS50 and had a chance to compare the LS50 Meta in my room and do a back to back comparison. Once you EQ the LS50 they are as good as Meta. Even without the EQ
I had to really focus on certain aspects of a song to notice any difference. There were times when I forgot which one was playing. It's definitely not a night and day difference unless you are a trained listener. Hence I decided not to pay extra for the Meta.
I use Maiky76's eq on both speakers, and to my ears the Metas simply sound better. Much better. Smoother and more relaxed. I use (have used) both with an SB2000 sub crossed over at 100 hz, and with Dirac Live. My ancillary equipent is an Octo DAC 8 Pro, and a Puri Eval 1 Eigentact amplifer.
To my ears, the Metas are stunning with this set up. I've moved the OG LS 50s to surround duty. They sounded very good with Maiky's eq, and Dirac Live correction mated to the SB 2000, but not as good the Metas in the same set up.
Other people may hear it differently, but for me these speakers in my small listening space, playing at moderate volumes (l.t. 90 db) are about as good as anything I've heard, and I've been an audiophile for 47 years.
I suspect individual speakers of the same make and model can easily be +- 1db in their FR due to minor driver and material variations, though I have not seen anyone confirm that scientifically.
So I would trust more, and will do when time permits, my own windowed measurements to allow individual EQ of the units I own.
I own the original LS50 and I borrowed my brother in law's Metas for a week because I wanted to AB them in my own house. Didnt have to, difference was quite huge in terms of body, transparency and clarity, all goin to the Metas. AB-ed them to be sure and back to back the difference was even bigger. Soundstage and instrument separation were noticebly different, I have not eq-ed my LS50 but I dont think even after EQ-ing them would put it on par with the Metas in certain important aspects. There are somethings you just cant get by eq-ing. I am now itching for the Metas but cant quite afford it yet. This is from someone that owns the LS50 for more than 3 years now. Or I might just save up more and get the Wireless 2 and be done with because I wont need to splurge on an amp that goin to cost at least twice as much as the Metas to bring the best out of it.
That active crossover and dsp are really attractive. Ive seen too many mismatched LS50s and Metas, making them sound 'worse' than their active counterparts.You don't need an expensive amp for the ls50s. A $500 hypex is plenty of power for them, and has no problems with impedance.
I would avoid the wireless version... KEF doesn't have a great track record with their electronics
Both will require a sub.. and s sub will always add high pass/placement issues. Stretch the budget a bit go for a kh310
Whats wrong with KEF and their electronics? Many Wireless and Wireless 2 broke down before?
Totally agree with you about actives being better. But I think with the meta's we're at the point of being audibly perfect when used with a subwoofer. Which makes the deeper bass of the wireless moot. The actives will likely measure perfectly but I would assume at this level, the passive and actives would be difficult to tell apart. I personally would avoid their wireless models for the failure rate and considerable cost difference.
Where have you come across mismatched meta's?
For example, Cambridge AXR100/85, Audiolab 6000A, Marantz CR612/412, Marantz PM6007, Rega Brio, etc... Like I said, it will play but its quite far off what the Metas can actually do.What amps are LS50 Meta owners using?
Im personally guilty of this too but I cant afford a more powerful amp at this moment. I know what to do next if I wanted to up the game though.
Amps Im looking at now are the Peachtree Nova 500 and especially the Anthem MCA 225 Gen 2 in particular. That should bring the best out of the LS50. Im dying for a Rega Osiris and McIntosh MA8900 but its way way way out of my budget.My amps include a Yamaha A2080 AVR and Emotiva BasX A-100. I'm thinking about classing up my living room amp at some point and want Dirac included. I will probably get LS50 Metas next. My R3's are not working well with my smallish apartment and speaker placement options.
What amp are you thinking?
In Europe, specially UK the kefs are more expensive..go figure out and I guess the Neumanns cheaperAre these much cheaper in Europe? In the US, you'd have to stretch your budget 3X the Kef to afford the KH310 ($2295 each).
