respice finem
- Joined
- Feb 1, 2021
- Messages
- 1,867
- Likes
- 3,779
I guess the real "GaN popcorn time" may come to the forum one day - this is when the first Hypex / Purifi GaN modules arrive...
Yes, I like the SchiiT and JDS Labs stuff. It's priced fairly and closer to home.My preference runs to Made in USA
I think the technology is good although it does not seem too have matured yet at the implementation level.I rather like the GaN idea, although not enough to spend $$ to find out.
At the moment it seems to be solving the problem "how to put GAN into an amplifier", rather than actually making amplifiers work better.Yes, I like the SchiiT and JDS Labs stuff. It's priced fairly and closer to home.
It'll come.At the moment it seems to be solving the problem "how to put GAN into an amplifier", rather than actually making amplifiers work better.
It has potential for the latter, but an engineer or three somewhere need to work out how to actually do it in the real world. I'd like to see them shift the pulse frequency up as far as possible while keeping losses the same, so the output filter bandwidth can go way beyond 25KHz.
It seems quite a few class D amps (including this one) have distorted filter FR depending on load impedance, rolling off (or up) well below 20KHz. I'm assuming a wider band filter would make it easier to avoid that. Or maybe it just needs more competent filter design.It'll come.
Why should it go beyond 25KHz?
Hmmz... I see. I need to get up to speed on class D theory of operation. I just know what I've gleaned here at ASR.It seems quite a few class D amps (including this one) have distorted filter FR depending on load impedance, rolling off (or up) well below 20KHz. I'm assuming a wider band filter would make it easier to avoid that. Or maybe it just needs more competent filter design.
Either way a higher switching frequency should make it possible to significantly reduce any distortion products hitting the audio band.
All that have a principle based on hysteresis switching with output LC filter out of the loop. You cannot put it in the one global loop with this principle. So the modulation of FR is inevitable. TI PFFB concept is only a partial cure but it worsens stability. Add a nonlinearity in output inductor that is out of FB. So it is the principle regardless implementation. GaN or other cosmetic changes make no much difference. Yes maybe radical increase of switching frequency might help, still you have the inductor nonlinearity. The only advice is go discrete and make a serious design based on different than hysteresis principle, nowadays it means avoid class D chip of any kind.It seems quite a few class D amps (including this one) have distorted filter FR depending on load impedance, rolling off (or up) well below 20KHz. I'm assuming a wider band filter would make it easier to avoid that. Or maybe it just needs more competent filter design.
It is not a chip amplifier based on hysteresis switching. Would you please use a complete quote next time, not to misquote. Thank you.Do you include Purifi in that statement?
I'm not really sure what we are looking at in the pic. There are XLR connectors inside the layout that go nowhere and the wires are a bit of a spiders web. I think it's just a pic of stuff that is not really meant to serve a purpose. It's probably just stuff assembled to make a picture and not a actual thing one can buy from what I can tell.
Too bad… I rather like the GaN idea, although not enough to spend $$ to find out. My preference runs to Made in USA, with the UK next. Benchmark DAC/Pre and amps with Quad, Harbeth and KEF (although I think the KEF are manufactured in PRC).
BTW I wonder why @amirm does not measure output impedance vs. frequency in his reviews, he has AP and it would give us the answer immediately if the class D amp under test is worth considering.
I am not sure what you are trying to say here, my amps have feedback from both sides of the LC filter. Here is a block diagram. They are also fully balanced from input to output.
