Keep us posted as to how you like it.
All that I snip-ed are valid points. I am not one to advocate the "Price Point" issue but here we are comparing a dirt-cheap, entry-level speaker with some that are several times its price. A better comparison would have been with the JBL "7" series. Don't they (JBL) have a "4" series?<snip>
I've heard plenty of nearfields in my life from Klein+Hummel, Adam, Geithain, PMC, etc. And know what they can sound like when properly set up.
Good points: They're dirt cheap, other speakers in this price category have huge faults of their own and usually sound less musical. Another good point is that when set up properly they are fairly balanced frequency wise, not purposefully hyped on top etc.
I suppose I would ask what is a better choice for $300/pr in powered active speakers? Or even $400/pr?
I've not found the EQ switches to be a problem degrading sound.
I think the bass is a weak point, but in a 5 inch woofer in such an inexpensive box you are lucky to have any. Which is why I think for anything other than near field use one is smart to add a subwoofer. It makes the bass better, and relieves the 5 incher so it can work better over its range of frequencies.
The balanced frequency response is why I think it is a good speaker in absolute terms and stupendously so at $300/pr. Plenty of high end speakers have other advantages and get that wrong. Sometimes thrillingly so, but still it isn't hifi.
Ah no, I don't know a better choice for $300/pr in active speakers. (though I wouldn't be surprised if it's there, perhaps from Edifier, and in Europe the Focal Alpha 50 is about the same price as the 305p mkII though I haven't heard it)
But what got me are the rave reviews of how this is "high end" etc. And just saying that by listening to the LSR305 (first version) is that it doesn't cut it for me to be called high end. Too many errors that are just a bit too colouring for me.
Though perhaps the mkII fixes most of these enough to make me like them! I'm still having some hope even though most people seem to say they sound about the same (but then again those same people said the first version sounds steller which I don't agree with either so perhaps they don't have them set up correctly or in a bad room and don't have experienced ears etc)
I've been doing some more reading and it seems like the mkII has a different bass driver which doesn't compress as much, stays more centered and has lower distortion. That would be great. Also the treble driver has changed to one with ferro fluid and is stated to have better transient response and a more even response. And it seems the cabinet has changed to what could very well be thicker MDF, it is less deep as well in the mkII version.
Well funny enough all these changes could exactly hit most of the points I'm having troubles with Seems like JBL's designers have ears too.
So again maybe the mkII version is a considerable improvement to me. I'll know tomorrow
Oh and I found another thread where the cabinet resonances are measured and a fix is proposed for the worst of them by adding a cross-brace (which all of these cheap cabinets should have to begin with). Without it it is described and measured to ring like a bell. So it's not just my ears.. http://www.diyaudio.com/forums/multi-way/320206-jbl-lsr305-tweaking.html#post5375155
For nearfield applications, I would say that the Eve sc204 is many many levels above the LSR305 mk1 (haven’t heard the MK2). For just a bit more money. But bass extension and max spl is obviously limited. Hence near field - and ideally crossed over to a sub. SC205 is even better, but is more expensive.
Eve makes great speakers in general. I like the AMT tweeter, and I like that it doesn’t have a waveguide which can color the sound (for nearfield use the direct sound is much more important anyway).
Unless a driver is a naked levitating diaphragm, it has a waveguide. Every baffle is a waveguide. A baffle loads the driver down to a certain frequency, has a transition range, and constrains the driver's radiation.
Here's an example with good measurements: Ascend CBM-170 SE polar measurements from the Princeton 3D3A Lab (BACCH).
This speaker has a 6.5" woofer and 1" tweeter on a 9" wide, 12" tall flat waveguide. Here is the 360 degree polar map:
https://www.princeton.edu/3D3A/Directivity/Ascend Acoustics CBM-170 SE/images/Plots/Horizontal/Ascend Acoustics CBM-170 SE H Contour Plot.png
Aside from the obvious problem (midrange dispersion disruption due to the bad crossover region DI match between woofer and tweeter), you can see that the flat waveguide does a very good job of constraining the tweeter's radiation to the forward hemisphere. Shrink the waveguide down to 4" wide, and you would see considerable rearwards radiation at the tweeter's low end.
Another big issue with flat waveguides is edge termination, because they send so much energy to the baffle edges. Sharp edges from baffle to sides are a lot cheaper to make than roundover or chamfer transitions. A more contoured waveguide sends less energy to the edges. This relative lack of energy makes an abrupt transition from baffle to side less problematic.
Best case is a contoured waveguide that transitions smoothly onto the baffle, and rounded or chamfered transitions between baffle and sides. All three of those are unlikely to happen at a budget. The best realistic case for a well priced speaker is a molded contoured tweeter waveguide, which is barely more expensive to make in quantity than a flat faceplate, in a standard sharp edged box.
Thanks! Enlightening comments.
As with everything in speaker design, there might be trade-offs. There is no doubt that non-flat waveguides may improve the dispersion characteristics and the polars. At the same time, isn't it the case that what is commonly called a waveguide (i.e. not a flat baffle) does something with the soundwaves beyond controllring dispersion which a flat baffle does not? I'm thinking of HOMs etc, re: Geddes. One may discuss the audibility, but my understanding is that it's there, and that it's measurable (using the right measurements). On the other hand, THD probably becomes lower, because the drivers get an easier load. So I do think there's a trade-off.
Subjectively and anecdotally, I have had an increasing suspicion that waveguides do something to the sound that I don't find optimal for long-term listening, and that I prefer flat baffles, in spite of the obvious shortcomings of the common sharp-edged variety.
That's basically correct re: lower nonlinear distortion vs greater diffraction (inc. HOMs).***
This diffraction has proven difficult to measure, however, and although it theoretically must be occurring, I've looked for experimental evidence of it and have not been able to find it (not even Geddes has provided any experimental evidence of HOMs, for example).
There's also, to my knowledge, no experimental evidence of their audibility.
***It's not quite that simple, because there's also the question of diffraction caused by a flat baffle. To eliminate baffle-related diffraction in a direct radiating speaker, the baffle needs to be spherical or heavily rounded at the edges. I don't think it's a stretch to say that most direct-radiating tweeters are generating similar levels of diffraction to most waveguide-loaded tweeters.
No problem trusting your intuition that you prefer the sound of direct-radiating tweeters.
It's just that - without any experimental support - I wouldn't jump to any conclusions about why.
On HOMs, I was under the impression that it had been decisively measured... am I wrong on that? Bjørn Kolbrek lists the literature here: http://kolbrek.hoyttalerdesign.no/index.php/blag/28-higher-order-modes
Yeh, if you browse through all that material listed, you'll notice that all of it is theoretical, with the possible exception of this article.
I'm going to read it and get back to you on what the experimental findings were and what they might mean (as I'm interested myself - it's not a study I was previously aware of).
Cool! Thankful that you read it, so I don't have too The same guy also wrote this article, which seem to contain further measurements of different horns/waveguides. http://www.aes.org/e-lib/online/browse.cfm?elib=13294
Just to be clear: I do realize that there are advantages to horns and/or contoured waveguides. I've heard some very large horn systems which have made a lasting impression on me, when it comes to dynamics, punch, etc. Have even been thinking of getting (big) horns myself. At the same time, my intuitive impression is that there are trade-offs. But as you say, this may be due to many different things!
