Lyngdorf TDAI-1120 questions
stevoknevo
Has anyone been able to run apple airplay stream higher than 16/44,1 mode? This seems to be a default resolution for stream uptake regardless of the media quality from Apple Music.
That's purely a limitation of Airplay (and apparently it's not always lossless despite being 16/44.1)
Nope, almost all LED burned out in my case, this seems to be a frequent problem. I personally have issues sending it back, so probably will have to give up, unless DIY solution comes up. It is pity to see such problems on a device of this price.
I wouldn't go as far to say it's a frequent problem, yours waas the second 1120 I've heard of it happening with (and now a third unit above with @Oblomov ) - Lyngdorf repaired the other one quickly at no expense to the owner, however for whatever are your own reasons, you're unable to return it to be repaired ‍♂️
