M2.5! speaker from PBN Audio: Waveguide Horn and Dual Woofers
Sir Sanders Zingmore
Melbourne, Australia
Two JBL drivers are the heart of the system: First, twin JBL 2235H 15” woofer classics, with a low-loss magnetic structure and Symmetrical Field Geometry, which reduces harmonic distortions to near zero. The second is the inimitable JBL D2430H mid-range/tweeter compression driver, with dual-diaphragms.
Hrodulf
Latvia
That’s a pass for me at 30k. Low end seems a tad shy for the size and price. I’d rather swipe a pair of M2’s, get a quad nCore setup and run them from a RME ADI-2 Pro with digital filtering.
Ron Texas
Those ought to blow you out of your chair.
jhaider
Two 2235H woofers have about as much volume displacement as one of their new neo woofers. The 2235H is also a little fragile. The mass ring can get stuck. I think the preferred approach today is to use their version without a mass ring and actively equalize the bass.
mitchco
Yes, surprising choice for the woofers - not sure why they did not go with the modern dual VC neo 2216Nd. to match the D2430H that are in the JBL M2's...
I like the double 15's approach thought. Same approach as the JBL 4722 Cinema speakers. While the 4722's are fugly, and use a slightly lower grade version of the 2216Nd, they are also $1K per speaker, yet have as good frequency response as the M2!5's...
