Macbook VS. Bluesound NODE N130
BjarniM
Cheers.
I am using this setup at the moment:
Macbook Pro (2021) playing music from Tidal via the headphone jack to a pair of Genelec 8030C studio monitors.
I am thinking about buying a Bluesound NODE N130 and connect my monitors directly to the N130.
Will I get a better sound quality? Anyone here with a qualified opinion?
Thanks in advance.
Jhify
According to measurements I've seen bluesound performs worse. If you don't intend to use its features it would a waste of money even if it performed better. If you're in Europe and and just want airplay2 I'd suggest you have a look at the Argon Audio solo. If you don't need to be cable free better to stick to the headphone jack.
staticV3
MacBook Pro 2021:
NODE N130:
Bluesound Node Measurements DAC Wireless Multi-Room Hi-Res Music Streamer.png
Unweighted Dynamic Range is 109dB on the Node and 125dB on the MacBook.
So no, you won't get better sound from the Node.
Sources: MacBook Node
