Mains noise and instability
GrimSurfer
Wow. That's a big difference in ambient noise.
RayDunzl
Central Scrutinizer
Riverview FL
Tks
I thought daps can't feed senn hd6xx, ok i will search for more
What? I can literally drive it off an old iPhone 5, iPhone SE, iPhone 6+, iPhone 7, iPhone XS Max...
All work perfectly fine for home use of an HD6XX, especially if the alternative is using an amp that you can audibly perceive issues impeding your enjoyment.
solderdude
The Neitherlands
Dac or amp? Which one is affected more from the problems
Impossible to tell, depends on many factors including its wiring.
It is even possible that neither shows any influence untill they are connected.
Y
yigitboy
Turkey
Yes maybe they can play loud but lets not say perfectly :)
Reactions: Tks
Veri
For many people it would be sufficient. Not everyone wants the physically-vibrating kind of experience Amir stress-tests devices with :) :D
Y
yigitboy
Turkey
I bought an online ups. Surprisingly all problems gone. Dynamics, detail and instrument seperation is at top what i can expect best from my devices.
It is like listening at 03:00 am. Maybe Graham slee solo and my updated amplifier ( SDF Audio3 tube amp )'s electrical components were the problem. I dont know but absolutely it is not placebo. Even my eardrums started to vibrate which never happened before even at the last volume.
I dont know if it works for you but mine did.
jsrtheta
Colorado
Not to be snarky, but it absolutely could be placebo. Not saying it is. But if you're going on subjective observation, yeah, it could be placebo.
Y
yigitboy
Turkey
We can not be sure without measuring how the amplifier deals with dirty electricity. If it is placebo, i would pay a lot for such a nice placebo :)
jsrtheta
Colorado
Or, you could do a DBT, which is what's needed to be close to sure.
