Major confusion over Motu M2 - a lot of conflicting reviews
malp
Expounding further do you know what sounds different if two identical devices differ by .4 db? One sounds like it has more extension at both ends a deeper richer soundstage and just a better sound. It does not sound louder, it just sounds better. This is a widely known phenomenon. You need careful matching to avoid it. Using music and an SPL meter no matter how careful, you aren't going to get matching within .1 db which is what you need. You cannot educate or train yourself out of it or around it. You just cannot do it.
The ID14 sound great with less volume, same volume or high volume. It always sound better than the M2.
Don´t tell me that I need a meter or an instrument to measure what I hear, because when I know, I know. You know when you like something. Trust yourself, man! Life is about enjoying, not measurements only.
Blumlein 88
Uh huh!
Trell
Ok, let's say anything better than a baseline 100$ interface is all placebo, well it may be chances are it is.
That is a straw man argument as no one is claiming that.
Trell
If you get fine measurements for 100$, which you indeed can get, that IS what everyone is claiming ...
That’s not what you wrote in the post I replied to. I think that one can get devices that measures fine for $100, but not everyone is claiming that either.
xeizo
It's no meaning circle jerking around the issue, anyone interested in those interfaces should look at hardware features and quality of the OS-driver instead. And maybe output power of the headphone jack, if that is to be used. Much more important than perceived/imagined SQ.
Measurements of greater interest for a interface is noise level of the mic inputs as some mics have very weak output signal(Shure SM-7), that differs a lot between interfaces. Also a larger headroom lessens the risk of overdriving the inputs, it's a important figure. Lastly, some interfaces dont fare very well with High-Z sources like guitars and keyboards, that is a thing that needs to be checked.
SQ on the line outs is probably the least important quality of a interface as most/all sounds very good.
Chrispy
PNW
I understand but is more than enough for me.
You are easily fooled most likely is my conclusion. You didn't conduct a proper test. How can a dac improve soundstage (do you even know what soundstage is?), let alone be more "musical" whatever the hell that means? Why would anyone trust you?
Blumlein 88
It is all in that magic soundstage mojo. If your gear (and ear) isn't good enough you wouldn't understand. I bet old Arny wouldn't either. ;)
Koeitje
I also listened to both of these and thought the M2 clearly had a better sound stage. What now?
Chrispy
PNW
Indeed, what now? What does that particularly mean or prove? Define soundstage perhaps.
Koeitje
Blumlein 88
You must have used poor cheap gear and don't have the adequate experience with good stuff. What else could it possibly be?
jae
Ok, let's say anything better than a baseline 100$ interface is all placebo, well it may be chances are it is. But even if it is placebo, it will still be more pleasant to work with the interface you prefer even if it is all smoke and mirrors.
On a more practical level, features and implementation of those is more important. Wobbly buttons as the Audient above kills the experience.
I agree, but no one is really arguing this though..? Those going through great efforts to explain that it will sound identical are simply stating just that. It's been indisputably demonstrated that properly engineered $100 dacs/adcs/amps, even a $10 USB dongle has the ability to audibly transparent within its operational specifications, what you are paying for is power, features, implementation, aesthetics, build quality, brand name etc. Most of the time a majority of that cost is brand name and even conventionally reputable brands have an abundance of problems. That's a big reason why this site exists, to make consumers aware of issues with products and to make better informed purchase decisions based on the objective reality of audio science.
Personally, one thing I hate about the MOTU is the that mic inputs are on the front. I have one or two permanently connected microphones so this is annoying for me and causes extra clutter and makes my desktop surface not look as good, but it's something I obviously knew buying the product and a subjective problem- someone might love the convenience of the inputs at the front and consider it a feature. Similarly, if I had to drive demanding headphones with my MOTU I would not have gotten it, since the main reason for the purchase was specifically to have an all-in-one interface that could be used when traveling.
As for M.2, it has documented problems changing sample rate on Windows, that is a real problem and makes usage sometimes clumsy and un-intuitive. A problem most other interfaces do not have even a trace of.
I don't think I ever had this problem personally, when I first got it there was sometimes a brief silence when switching rates but I don't notice it anymore, perhaps it's fixed with a firmware update? Perhaps using it in exclusive mode/ASIO should not cause this?
The ~0.3-0.4 dB rolloff (and only 0.1-0.2 dB at ~35-40hz) at such a narrow band deep into sub bass is hardly audible with test tones let alone with music that dips that low, never mind with the 99%+ of music that does not even have any spectral content or psychoacoustically unmasked content in these octaves to begin with. Sub bass minimally affects sound localisation and in fact, deters from it at worse. Most sub bass is not even stereo mixed. A tiny bass rolloff simply explains none of the "soundstage" claims in this thread even if they were matched! It would be nice if it was more ruler perfect like other products, but it outshines comparable products in virtually every other metric to the point where this shortcoming is virtually meaningless. As you said none of the "obvious" psychoacoustic effects these people claim to be hearing between the two interfaces would even be remotely explained by such a deviation, and they aren't even accurately volume matching, so in my view whatever claims are simply nonsensical.
Ok. Got the two side by side. And Ive test it with my eyes closed and I have to state that the Id14 it is much more musical than the M2. It´s like it is more 3D sounding, the soundstage is much clearer and open.
It will be dificult to make a sound test to prove this but I can try with my field recorder.
Regards headphone output I prefer the M2, sounds really good, warm and musical, good sound stage. The ID14 in this case, sounds colder, less sound stage.
Regards construction the M2 is rock solid. The new Id14 mk2 came with the volume pot a bit wobbly, it sucks. But I am returning the M2. I almost don´t mix with headphones.
Volume matching problems aside, what headphones did you use? I already showed data showing quite high output impedance on the ID14, so it is something that has to potential to change the FR of a headphone if it is low impedance, which already is yet another reason to invalidate informal tests of this nature. And even so, I definitely doubt this would affect the frequency response to a degree that the soundstage would sound clearly and indisputably more '3D'.
Gain and noise level of the front inputs are in the manufacturer spec sheet and noise is also confirmed by the 3rd party measurements I posted earlier, there are a number of youtube videos corroborating the measurements as well. Others have measured those outputs at various gain levels, even with output monitoring on and the mix dial at various settings the FR stays virtually the same (+/- ~0.1-0.2dB) throughout the audible band.
I use it with a SM7b regularly and have no issues. I threw a se dm1 dynamite on it since I had one laying around since I mostly use it for voice chatting at my desk and sometimes having the extra headroom is nice for adjustments on the fly since I speak at various distances and volumes throughout the day. If you are using it in any 'professional' recording capacity the interface alone is quite enough for similar gain hungry mics. Use it with a high-Z bass as well. I agree that more comprehensive measurements of the other inputs would be a nice asset. All the 3rd party measured specs are in line with the manufacturer ones so I'm inclined to believe whatever unmeasured claims from the manufacturer are believable.
preload
California
I have an M2.
Works great as a mic preamp and volume control for Zoom calls.
But the unit feels very cheap.
kemmler3D
San Francisco
I'm a rebel so I'm going to tell you that. This is why measurements exist, because ears are pretty unreliable for this kind of thing and brains are even worse.
If we legitimately, honestly, in real life, didn't need measurements to hear small differences and identify what they are, engineers would just use their ears because measurements would just slow them down. Why use an oscilloscope if you can just listen and identify that <1dB change accurately?
But... guess what?
dshreter
I have an M2.
Is funny, for $200 I think it seems very nice. I like the feel of the volume control, and all of the connections feel robust.
jae
I agree, the main competitors that are in the same formfactor like the focusrite scarletts, behringer, presonus, focusrite etc. are of lesser or similar durability but more plastic-y, and the ones of comparable or greater robustness have their own problems.
computer-audiophile
Germany
BTW: When it comes to mechanical quality:
I bought the TASCAM US-1x2HR audio interface a few days ago because I want to use my electric guitars again. It cost about 100 euros.
The overall impression of the design quality and aesthetics is very good in my opinion. It has a metal case and the side panels are cast metal. However, I would have preferred if the USB port was not the mini-plug version.
The sound in CD resolution is pleasant and subjectively comparable to the previously connected Topping E30II. For me, the Linux compatibility was still important, since I use Ubuntu.
HarmonicTHD
Seems like you can run your car over this one while recording and playing back. Yeah noise level might suffer ;-)
xeizo
I have the 2x2HR in one of my systems, very sturdy yes, also one of the interfaces with the most noise free mic inputs out there. It uses Cirrus CS4272 as DAC-chip, which is never used in "HiFi" DAC:s but often used by Focusrite etc in this category of home studio interfaces. Again, subjective, as I haven't done any scientific comparison it sounds very good and I haven't found any shortcoming compared to this threads M.2 except no flashy meters and headphone out is a bit weaker but which is a no problem with easy to drive modern cans. Windows driver is excellent and has caused exactly zero problems.
