What is THD + Noise? Sinad is exactly the same thing as THD + Noise. You need to be careful looking at SINAD as a headline figure. For example Amirs table of SINAD performance has some clear leaders, most of which because they output a far higher output voltage.
The noise floor remains the same, the apparent or listener perceived noise floor remains exactly the same. If you couldnt hear it before attenuation, you wont hear it after attenuation. Equally if you cant hear the noise floor, you wont hear music that is at or near that low level. You have lost nothing.
It is the dynamic range / SNR that changes.
Please feel free to buy the O2 or Odac, my amp may not be right for you.
Pots are horrid, balance issues, noise and degrade over time. Analogue volume control is *not* perfect. Analogue controls also degrade dynamic range/SNR once you hit the noise floor of the partnering amplifier, which may not be that far lower than the DAC. In fact speaker power amplifiers it most probably will be higher than the DAC.
Digital volume is very convenient in the app you are running on your phone or tablet.
The problem here is that you have lost real world context.
I meant the noise floor degrades compared to using resistive attenuator,the apparent noisefloor from listener perspective does get higher if the DAC is attenuated digitaly versus using pot to turn it down.There is reason why pots are used when money,space and weight isnt issue.
I do agree digital attenuation is better,thats why I like the idea of this amplifier,the superior reliability and channel matching are winner in my book.My issue is that I think the amp should not have any gain if it wont have gain switch.
With regard to your SPL test,it just confirms what I say,you listen 2db louder with compressed music and 8db more with uncompressed.With HD650 thats like 650 mV rms for 100db peak.HD 800 would be 800mV,the extreme outlier that is Hifiman HE6 would need about 3.2 V for 100db so on unity gain amplifier it would get to only 96db.
Even this ridiculous headphone would play loud enough for you with 2db to spare on compressed music and would fall short of only 4db with more dynamic music.I think designing amplifier around this extreme outlier is bad idea,how many people in the world have HE6? How many people with HE6 plan to use your amplifier?
Becose increasing gain is no free lunch,if you want to satisfy these rare cases,it will be at the expense of majority,I bet there will be many times more users complaining of hiss,particulary the IEM users compared to HE6 owners who would get "only" 96db out of unity gain amplifier.
Its true for full sized open headphones the noise floor would not get audible even if you made your amp with +6db gain but sensitive closed headphones,particulary IEM could make the hiss audible.If you have 30db noise floor in your room and you have closed headphone with 30db isolation at 2 KHz+ frequencies then its like if the noise floor was 0db,and if you play dynamic music with 100db peaks then you need 100db SNR for hiss to be inaudible and with 20- 30 db of digital attenuation with full sized headphones and god knows how much with IEMs,you are absolutely in hiss territory.
Also the higher the gain,the higher the chance of unpleasant experience when one is blasted with loud sound.There was mentioned that crashing Windows or some other software issues could cause the digital volume to be turned full on,even if that wasnt the case,user error is in my opinion much more possible route to this noise blast issue.With +6db gain and Hifiman HE 400S it would blast you with 120db,IEMs would probably explode.
