- Thread Starter
- #281
Funnily enough Mogami is what I have just ordered.
I like the sound of that! Hope to see you follow thru on that promise.Any colour you like as long as its black
Amphenol connectors. Although available in various colours, I have settled on the silver ones for the RCA/TRS and black for the XLR.
Cable will be Belden/Canare/Mogami, actually still musing over the best options but either way you wont see any audiophile solid silver cryogenically treated nonsense, just technically correct high quality parts.
.........and of course if you really want braid that can be added as an option (it will of course improve sound quality by at least 206.3% ).
...The Nc500 OEM module is better performance again,( wow).
The Nc122, 252 and 502 are little behind in terms of some parameters, but still very much top teir. I will get together some comparison data and plots.
Hi
Yes that's the P701 monoblocks. Due in a month or so. I need to make some modifications to the casework before release, but the headphone amp is the current priority hence a bit of a delay.
It's annoying that the Web shop can only currently accept one currency type although can choose what, hence being international its best set to USD.
This can be a pain with potential credit card fees and exchange rates. However if you are AU based we can do direct bank transfer to avoid this hassle.
So
- P122 - Stereo 125 watts into 4 ohms - $650. $900 aud
- P252 - Stereo 250 watts into 4 ohms - $800. $1100 aud
- P502 - Stereo 500 watts into 4 ohms - $1000. $1380 aud
- P701 - Mono Block 700 watts into 4 ohm - $900 ea. $1245 aud
You certainly can use it with a pre amp, however it can also be driven directly from a DAC and use the DAC or software digital volume.you still need a pre-amp for this right?
You are consistent in putting Left/Right on the wrong side
Why?Some Rhodium plated connectors would be nice too.
Hi @Totoro Since the Nc1200 module has become available I made the decision to not offer an Nc500 unit. This decision has been re-inforced by the arrival of the Purifi 1ET400 which with its improved performance, to my mind, in effect makes the Nc500 obsolete. If you want/need more power and drive capability then the nc1200 is a better option than the nc500.Hi, do you plan on making an nc500 version of your amps at some point?
Makes sense, but entails a massive price jump. I guess I’ll have to save my pennies for a whileHi @Totoro Since the Nc1200 module has become available I made the decision to not offer an Nc500 unit. This decision has been re-inforced by the arrival of the Purifi 1ET400 which with its improved performance, to my mind, in effect makes the Nc500 obsolete. If you want/need more power and drive capability then the nc1200 is a better option than the nc500.
The next product will be the P451 Purifi based monoblock. A stereo unit would require different casework so is further down the track.
@March Audio -- FYI, the direct links to the amplifier pages in your sig are broken. Link to main site and DAC etc. are OK.
