March Audio Sointuva Speaker
Status
Not open for further replies.
March Audio
March Audio
Albany Western Australia
Over the weekend I found a problem with the speaker cable used for the testing. A loose connection was casing a (relatively) high resistance which was having an impact on the response. After fixing a further XO tweak was necessary, but the end result is that the data has improved.
On Axis
Somerville, MA
So, what's the value proposition you'd make for this speaker? It seems like a good design, the measurements are great, seems well thought out. Does this blow away other small speakers in terms of output?
Also did you figure out the source of the 350hz issue? I doubt it's significant if it doesn't show up in the FR, but I'm curious if you've isolated it.
March Audio
March Audio
The value proposition? Well first thing is these will be custom made to your aesthetic taste, be it colour or the wood finishes that are available. There are a lot of reasonable performing speakers out there but many of them are aesthetically terrible IMO. Im not interested in cheap ugly plastic finished boxes however good they may technically be.
So, how does it sound? Yes it does blow away many small speakers. Firstly the bass goes down a very long way. F3 about 45Hz and F6 about 38Hz. Dont know of many, if any speaker of this size (w24cm x d21cm x h45cm) that goes down that low. It does it with exceptionally low distortion. Whilst there are a bunch of active speakers out there that feign going that low, they often do it with massive distortion as they are actively equalised.
I generally have a preference for closed box speakers because to my ears many ported boxes can sound quite loose and uncontrolled in the bass. They often have artificial peaks in their bass too. Whilst the passive radiators in the Sointuva do the same job as a port, they seem to do it much better. No chuffing noises from air flow and tight controlled bass like a closed box, but extends much further down like a ported box can.
The quality and depth of the low frequency response makes a disproportionate impact on the perceived sound quality, its extremely important. I will try and find the Floyd Toole quote on this.
The low distortion means that the sound is crystal clear – you sort of realise how much “fuzz” other speakers are introducing into the sound, and how difficult it is then to hear subtle details which are plainly obvious on the Sointuva. The high frequencies have a “liveness” (only way I can describe it), yet the sound is warm and not over bright like many speakers in my experience.
I lost half of yesterday afternoon because I ended up so engaged listening to music on them :) They just sound fantastic, but I would say that ;)
yes we know what the 350Hz issue is, will be sorted. Im also going to bring down the 2.5kHz bump.
MZKM
Land O’ Lakes, FL
tmtomh
I'm looking forward to the final product here - this could be really great.
617
Somerville, MA
I find them quite attractive in the white gloss cabinets. I'd tweak the badge and use SS machine screws instead of the black.
I agree with your comments on passive radiators; I like sealed and T line speakers but a good PR design really does check all the boxes, and the only way to go for a high end small design.
restorer-john
For me, the badge (although nice in a way) looks wrong. It should keep the black screws but be a black badge with white paint in the engraving. That would match his actual logo, look better and match the black drivers and driver bolts IMO.
617
Somerville, MA
Four words: front mounted L pad
March Audio
March Audio
All input and suggestions welcome :)
Mnyb
Sweden, Västerås
The low tuning for the bass is also a factor we don’t hear distortion or other problems that low in frequency.
So a low tuning helps both PR and BR speakers ( hence why I think ported subs are alright if big enough with a low tuning )
But as other products have shown this low tuning in a small box would make a big port with all kinds of problems.
So this driver and box combo sort of points you to a PR implementation ?
restorer-john
I guess you also need a badge that looks good across all colours and finishes. Tricky eh. The Japanese brands used gold (anodized I guess) engraved badges on their TOTL speakers & gear. Your large badge looks good on the Sointuva filling in the space under the woofer.
rajapruk
Very nice looking speaker.
I have not read the whole thread, but is there any diagram showing the vertical dispersion?
whazzup
You had me at d21cm....
I'm assuming desktop nearfield use is not an issue?
Phorize
U.K
At the risk of coming across like a philistine, have you considered using grills? It’s obviously a subjective taste thing but I don’t like looking at drivers usually, and the purifi ones are no oil paintings, at least to my eyes.
MZKM
Land O’ Lakes, FL
Agreed.
I don’t know how a typical grille would fit on this speaker though. More expensive (I assume), but a plastic grille just on the woofer like my Wharfedale’s use would likely be a deciding factor for some that just hate the look of the Purifi’s surround:
It’s not magnetic, put fits into the screws.
Status
