Mark Levinson Replica Amp
Krunok
Zg, Cro
Makes sense. I think the way an amp interacts with various speaker loads will affect its sound.
Two amps that can drive the same speakers without clipping and with sufficient linearity should sound almost indistinguishable.
But that doesn’t necessarily mean those two amps will sound the same on a different set of speakers
I believe it's the low speaker's impedance that causes most of the problems for amps. If impedance is ok than vast majority of amps operate well and within their specs. But even with "problematic" (from impedance point of view) speakers like electrostatics, whose impedance falls below 2 ohms, this happens after 10khz where signals are not that high so chances are most amps will actually manage to get it unless played very loud or the music material is so specific that it has strong signals there.
Sir Sanders Zingmore
Melbourne, Australia
I tend to agree with Roger Sanders (note the “Sanders” in my moniker). To paraphrase, his view is that most amps are underpowered into most “normal” speakers. Even at relatively low volumes they don’t have enough headroom to reproduce transients without clipping.
This clipping is very short lived and often isn’t identified as clipping by the listener. However, because different amps behave differently when they clip, it is identified as amps sounding different
TBone
I don't really believe in subjective impressions that are not backed up with specs/measurements ...
Whatever floats your sonic boat ... since I've not measured 'em with my speakers, and have no plans to do so, I'll refrain from discussing 'em any further.
The following review includes a very detailed circuit description, DBT test (vs Onkyo M510), and a subjective review.
http://www.hifi-equipment.com/5-classe-audio-dr-3.html
Krunok
Zg, Cro
It would be easy to measure if such clipping occurs during playout so no need for guesswork there. It would be even easier to measure if some non-orchestral "typical" music frequently have such dynamics that would require power of say 200W to handle transient peak when playing on medium power of 10W. Somehow I suspect any of this happens, but if it does there should be a lot of proof on the Net because it's really not hard to measure such situations.
One of my earlier speakers were Zingali horns, quoted at 96dB efficient. Using a CRO, I saw my 50w amp clipping at only slightly louder than my normal listening levels.
The waveform clearly hit a brick wall. It was “blink and you’d miss it” short lived but it was clearly happening.
So, I agree with you that it’s not hard to measure (if I could do it, anyone could :) )
Krunok
Zg, Cro
Sure. But such clipping occurs pretty much only with low frequency slams. Although it results in increased distortion our ears are much more tolerant in that part of the spectrum than if the same thing would happen in higher end of the spectrum.
The other part of the story is that SS amps clip in a very "ugly" way as they work on relatively low voltage while tube amps clip in a much more "softer" way as the clipping doesn't occur when hitting the voltage ceiling.
I think Sander’s point is that why would you want your amp to clip at all?
Also, different amps react differently when they clip and that is the primary reason that amps sound different.
So that takes us back to my original comment which was, if I can summarise myself:
- amps that are linear and are sufficiently powerful not to clip will be pretty much indistinguishable
- most amps are not sufficiently powerful. Therefore amps sound different.
Wombat
Australia
Most audiophile systems combine lower sensitivity loudspeakers with amplifiers below 75W RMS. Not a good match for performance.
Krunok
Zg, Cro
You certainly would not want them to clip at your normal listening levels. My speakers are of medium sensitivity (87db) and I haven't noticed any clipping with my 140W Rotel, but neither with 50W tube amp. Although, as I said, I'm not really sure one would easily notice clipping of a transient low frequency peak , especially with a tube amp.
watchnerd
watchnerd
Seattle Area, USA
Digital volume control and Class D amplification are two persistent audiophile bugbears.
Digital volume control, if implemented well, is completely transparent. It's likely possible but more difficult and expensive to achieve the same transparency with analog volume control. The IC solution for digital volume control in the JOB INT is probably fine. That said, because of the unusually high gain of Goldmund's JOB amplifier circuit, the JOB products are not a slam dunk; the gain seems to make them prone to hiss and grounding noise with most equipment.
Class D amplification can be fine, too. The three best speakers that I have heard--the Kii Threes, Dutch & Dutch 8Cs, and B&O BeoLab 90s--all use Class D amplification, and two of the three best systems that I have heard used Class D amplifiers (NCore amplifiers in one case, Pascal amplifiers in the other).
With these technologies, all depends on the implementation. The Nord amplifiers seem promising, but it's impossible to know without measurements.
My Devialet Expert 400 uses both Class D (actually it's their hybrid A/D ADH circuit) + digital volume control.
The digital volume control uses 40 bits floating point, which is 32 bits of mantissa and 8 bits of exponent, which means no loss of a single bit of precision on 24 bit content.
It's adjustable in +0.5 dB steps and, to my ears, is the theoretical a straight wire with gain, totally transparent.
FWIW, for most listening I have the gain set to between -20 dB and -10dB.
Dialectic
a fortified compound
I have a Devialet 120 in my second system.
Krunok
Zg, Cro
Dialectic
Krunok
Zg, Cro
Krunok
Zg, Cro
It's probably a fine piece of gear.
Yes, it probably is. I always like to see when power doubles when going from 8 ohms to 4 ohms. It is a sign of a generous power supply, and that usually implies the rest may be well designed as well.
