- Joined
- Jun 10, 2018
- Messages
- 6,257
- Likes
- 9,408
This subwoofer was recently discontinued and is now on sale for $700 (plus sales tax) instead of it's $1000 list price. At full price I probably would not have looked at it.
The 1000W has a 12' down firing driver in a 14" cube shaped sealed box with a 500 watt RMS amplifier. It has wireless connectivity via a stable bluetooth connection which I am using right now. The driver appears to have a plastic cone and a large synthetic rubber surround. Connectivity is limited to line level either dual RCA, LFE or wireless. Phase has settings for 0, 90 and 180 degrees. A crossover knob is marked 35hz at 7 o'clock and 120 at 5 o'clock with no other markings. I found an online tone generator which enabled me to do an approximate calibration. I have found the volume control is extremely sensitive at the low end. Because I am using it with low sensitivity LS50's the volume setting is pretty low. Advertised frequency response is -3db @ 22 hz anechoic. In room it's around 25hz or a little higher. Without room reflections the response is likely flatter and it mighture better.
The main chore in setup is avoiding room peaks. I used the reverse crawl method, LOL. That is, I have carried the 37 lb unit around the room and checked it's response at various locations. My solution may be counterintuitive because the sub sounds best very near one of the LS50's where apparent bass is not maximized. However, the speaker locations were chosen to minimize room peaks. Getting the sub away from room peaks minimizes the one note effect and allows a higher gain setting. Wireless connectivity made moving the sub around the room a lot easier because all I have to do is move it, sometimes unplugging it. Messing with cables is a lot more work. Also, I am using the DSP built into my Crown 1502 to roll off the LS50's.
My usual SQ comments, hints of diesel electric locomotives moving slowly and excavators pulling down old houses mixed with the comfy warm feeling of a kitchen fire while drinking bourbon laced with arsenic.
