Rod
Ya, the foam ear plugs are the only ones I could get to work on the right ear.
Frank Dernie
Oxfordshire
Nothing stays in my ears either including the noise reduction ear plugs (they just fall out). The only ones that work are the foam ones which is what I used with my Etymotic.
I had a specialist make a mould of my ears and make custom fit plugs for my Etymotic ER4S which have been excellent and much used on aeroplanes. Much more effective than noise-cancelling electronics IME too.
Thomas savage
The Watchman
uk, taunton
Yes , this servi is avalible on most high streets these days. Remarkable really.
Definitely. And weigh nothing compared to those huge Bose headphones people bring on airplanes.
tinger
Ebay has a 15% off today promotion thingy today.. up to $100
(I bought my IFI micro idsd black label via similar promotion a few months ago)
Rod
I have never used one of these but I thought if someone wanted to make pieces for broken parts like yokes this may work for a descent price? Might be fun to play around with too.
Monoprice MP i3 3D Printer Fully Assembled MicroSD & Sample PLA - Ebay Exclusive
https://www.ebay.com/itm/Monoprice-...xtbOFuq:sc:ShippingMethodStandard!95141!US!-1
$116.99
EBAY EXCLUSIVE 3D PRINTER
From the #1 Best-Selling 3D Printer Brand in the World (Source: CONTEXT Q3’17 AM3DP Report)
From the bestselling 3D Printer brand in the world, the MP i3 printer comes fully assembled and will be ready to print within minutes after un-boxing. The MP i3 features a large enough print bed for most projects.
MP i3 uses an open material system, which means you are not limited in your choice of materials. Filament is supplied on open spools and not in proprietary cartridges or spools marked with NFC tags which generally cost 3 or 4 times that of standard materials.
All you have to do is perform a quick check to verify that the print bed is still leveled, in case it shifted during shipping, then load the included MicroSD card, load some filament, and start printing the preloaded model.
Nowhere else will you find a 3D printer ready to print out of the box at such a low price.
Features:
- Ready to Print out of the box
- E3D Style Hotend
- Easy to Maintain
- For PLA Filament only
- Compatible with CURA, host by Repitator, Simplify 3D
- 110-250V (Auto Switch) 50/60 Hz
Packaging Includes:
1x MP i3 3D Printer
1x Filament Holder
1x Sample Filament
1x USB Cable
1x 1GB microSD card with SD card adapter
1x Scraper
1x PTFE tube
3x Hex keys
2x Spare print bed mats
1x AC Power Cord (NEMA 5-15 to IEC 60320 C13)
1x Leveling card
1x User’s Manual
Full Specifications:
SKU: 130441
Leveling: Manual
Extruder Quantity: 1
Max Printing Speed: 70mm/s
Maximum Printable Area: 120 x 135 x 100 mm
Filament Diameter: 1.75 mm
Material Support: PLA
Case Material: Steel
Insulated Cover: No
Software: CURA, host by Repitator, Simplify 3D
Accuracy: X-0.012 mm, Y-0.012 mm, Z-0.004 mm
Platform: Aluminum platform, non-heated
Platform Holder: Steel Frame
LCD Display: English/Chinese
Rail Locking System: Steel Bolt Locking Frame
Layer Thickness: 100 - 400 microns
Gross Weight: 19.4 lbs (8.8 kg)
Package Dimensions: 17.2" x 14.7" x 12.5" (437 x 373 x 318 mm)
Power Supply (Included): 110-250V (Auto Switch) 50/60 Hz, 0.95/0.56A Standard IEC Cable
Warranty:
30-day money back guarantee, 1 year repair warranty
Rod
$116.99
Features:
- E3D Style Hotend
- Easy to Maintain
Packaging Includes:
1x MP i3 3D Printer
1x Filament Holder
1x Sample Filament
1x USB Cable
1x Scraper
1x PTFE tube
3x Hex keys
1x Leveling card
1x User’s Manual
SKU: 130441
Leveling: Manual
Insulated Cover: No
Warranty:
Safety and Warranty Disclaimer:
This printer has been tested and certified, and warrantied to work with the Standard USA voltage and outlet. Monoprice cannot cover a warranty if the printer is used outside of the USA.Please note, our warranty does not apply to any defects resulting from negligence, misuse, any modifications or enhancements to the product. Any of these will result in a voided warranty, as a result, Monoprice will no longer offer support and/or returns for these items.
I just measured a hifimans yoke. Its just about 5x3 inches so this should work for just about any headphone pieces(not only hifiman) that could break. But if I am wrong please correct me and I will take this thread down as I dont know a dam thing about 3d printers.
maxxevv
You'll probably need a metal skeleton on the yoke to make it robust for daily use. 3D printed plastics don't take to repeated flexing very well most of the time.
Rod
Can these type of printers print around a metal object?
maxxevv
It will take a fair bit of planning and 3D modelling expertise to get it correct from what I have seen so far.
You'll have to create a lower cavity with the printer then place/glue on the metal insert that results in a flat top surface and then print on the remainder of the model on top of that.
Possible with good planning. But not a direct path at all.
Wombat
Australia
Same, here.
Timbo2
USA
Couldn't resist so I ordered it. :) So much amp with linear power supplies and such just for $135. Just the case and power supply is worth more than that!
Interesting in the specs I found at Parts-Express it is 80 WPC into 4 ohms at 10% THD. At 8 ohms and a more reasonable 0.1%THD it is 27 WPC. Naturally Massdrop only mentions the 80 WPC figure best I could see...
Not that this detracts from what is likely a solid little amp. I've wanted to try a Class T amp, but don't have any need.
I have a few of that class of Amp so I will do a shoot out at some point. Here are the guts of it:
Sal1950
The Chicago Crusher
Central Fl
Toys, toys, toys. Got to have them toys.
You'll play with it for a couple hours one day doing measurements and photos, then it'll collect dust until you give it to a friend. LOL
Wombat
Australia
Flirting with a 12-step program - Audioholics/Shopaholics (not so)Anonymous? Double jeopardy.
