Matching Luxman A-331 to my Focal Chora 806
vagabond
Hello,
I have the Focal Chora 806 speakers.
I thinking to buy an old integrated amplifier Luxman A-331.
As well I would like to use a DAC with the amplifier (possibly iFi Zen DAC V2).
Would this be a match or should I go for a newer integrated amplifier?
Thanks!
3125b
Germany
I wouldn't necessarily go out of my way to buy a 30 year old amp, but if you have it and it still works, sure it'll do the job.
What would be your application for the system? What does your room look like?
As long as it's is sufficiently powerful almost any amp will work just fine. You should worry more about speaker choice and room correction.
