Math of DAC -> AMP SINAD etc?
kenshone
Hey guys. Say you have a choice of buying an integrated DAC+amp vs. buying a DAC and amp separately.
Let's say the DAC/Amp combo under consideration has a SINAD of 115dB.
Let's say that the separate DAC has a SINAD of 120dB, and the amp has a SINAD of 120dB.
Does that mean that the combination of the separates will also have an input-to-output SINAD of 120dB? How would you compare the separates to the integrated option?
LTig
Europe
The combination would have 3 dB less SINAD as the noises add sup, so it would be 117. The 2 dB difference at this high SINAD is nothing to worry about. Choose according to other features or specs.
MCH
Need to take into account the volume control/gain. Will be different if it is digital (in the dac) or analog (probably the case if in the amp if separate). You can read this to get an initial idea (discusses only analog volume controls):
