- Joined
- Nov 16, 2019
- Messages
- 424
- Likes
- 679
As is commonly said, it depends.
See, if you have floodlight and a spotlight that use the same light bulb, it's guaranteed that the spotlight will be brighter- just in a smaller area.
Yet, with a speaker, there are no guarantees that narrow dispersion is going to be more detailed than wide dispersion. You cannot rely on dispersion alone to engineer a good sounding speaker.
However, should all be created equal (drivers, engineering prowess, well treated listening room, etc.), narrow dispersion has a greater potential to sound better than wide dispersion. It's just not a characteristic of high quality sound in it of itself.
This is a great analogy. However (not to criticize it), it doesn't differentiate between a possessed inherent potential and a possessed inherent quality.If speakers were lamps...
Omni - bare light bulb
Wide - floodlight
Narrow - spotlight
Each has its place.
